I need recommendations. I'm about to pull my hair out, trying to figure out all the different specs, and which is good quality and which is a rip off.
I need to place this camera in a drywall ceiling. I need the hole to be absolutely tiny and I need it to be wired. No wireless. What are your thoughts on this one?
http://www.dealextreme.com/details.dx/sku.805
It's B&W and I would prefer color, but if this is a good resolution cam, I guess I could live with B&W. Here are the specs on it.
The price is hard to beat, but I could handle paying a little more for something better. Thanks for any help!CCD VIDEO CAMERA
Pick-up Device: 1/3" B/W CCD
Horizontal definition: 420 TV lines
Picture element(pixeles) E: 290k C:320k
Minimum illumination: 0.1 LUX at F 1.4
Synchronizing system: lnternal
Scanning system: 2:1 lnterlaced
Video output: 1Vp-p 75 ohm composite
S/N Ratio(AGC off): More than 50 dB
Electronic iris(Auto): 1/50,1/60-1/100.000sec.
Gamma correction: r 0.45
Gain control Auto: 4dB-30dB
B.L.C: 2800k-8200k
MTBF 80,000 hours
Power source DC12V(Tolerence:9v-15v)
Operating current: 90mA w/regulated power in
Lens mount Standard: f=3.6(92°),f=3.7(90°)
You can get arrested in this country for putting cameras in the ceiling without consent . . . . .
You really have to try them out to see what they can actually do. All the very small cameras I have seen tend to produce low quality, noisy footage on par with a cheap webcam (which is basically all that they are). I have never bothered to look at the more expensive models to see if they are significantly better.Read my blog here.
I think you'll find all those b/w, pinhole, composite video cameras in that price range will deliver about the same quality. The biggest issue is the pinhole allows very little light through. Small lens = little light = noisy video, unless the scene is very well lit. The second limitation is the composite video signal. You'll get roughly 640x480 resolution.
Yup I wish I could do something better than composite, and would gladly pay a little bit more, but I've never seen one of these tiny cameras with anything but composite.Originally Posted by jagabo
Capture video from CCD camera through USB?
By vcao102 in forum Capturing and VCRReplies: 5Last Post: 7th Feb 2012, 21:07 -
HD Mini DV camera suggestion?
By alange5 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 14th Jul 2011, 13:51 -
Consumer 1080/30p CCD chip camera? HELP!
By BuddyT in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 11th Apr 2011, 15:29 -
Sony camcorder CCD-TR705 vs CCD-TRV95
By younso in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 8th Jul 2009, 16:32 -
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 03:18
