Hello,
I am trying to make movie from short video files using Vegas Movie Studio Platinum 9.0
Video camera I use is SonyHDD Hadnycam DCR-SR46. Videos comes out in .mpg format.
Neither when I play files in Vegas nor when I save movie to my computer, there is no sound for the videos in .mpg format. (There is sound when I open video in any player)
Here are all the properties for the files taken from Vegas
General
Folder: C:\PHOTOS & VIDEO\HIGH PARK. May 13, 2009
Type: MainConcept MPEG-2
Size: 40.38 MB (41,353,216 bytes)
Created: Wednesday, May 13, 2009, 3:56:02 PM
Modified: Wednesday, May 13, 2009, 3:56:38 PM
Accessed: Saturday, July 18, 2009, 7:01:41 PM
Attributes: Archive
Streams
Video: 00:00:35.035, 29.970 fps interlaced, 720x480x32, MPEG-2
ACID information
ACID chunk: no
Stretch chunk: no
Stretch list: no
Stretch info2: no
Beat markers: no
Detected beats: no
Other metadata
Regions/markers: no
Command markers: no
Media manager
Media tags: no
Plug-In
Folder: C:\Program Files\Sony\Vegas Movie Studio Platinum 9.0\FileIO Plug-Ins\mcplug
Format: MainConcept MPEG-2
Version: Version 2.0 (Build 5403)
Company: Sony Creative Software Inc.
Note: files saved in .wmv works perfectly in Vegas!
Could you please tell me what is wrong?
(PS: My concern is to play movies on DVD and to shrink the files size without loosing the quality too much, but still being able to use all the special effects that Vegas has)
Thanx in advance!
Results 1 to 12 of 12
Thank you for your answer!
This is all I found in the specs for the camera:
Video Format (Logical): MPEG2-PS
Audio compression format: Dolby Digital 2ch Dolby Digital Stereo Creator
Also, I downloaded tsmuxer and tried it. It does work when I play it in Vegas, but when I record movie and play it back, it doesn't have sound too...
Sorry, but I need your help again.
Thank you in advance! -
Hello, I am still in need to get the answer.
Would really appreciate any help!
Thanks -
If it works in vegas studio now (using the re-wrapped .m2ts file), but not on the dvd, what were your other steps and software used after vegas studio? (i.e. how did you author and burn the dvd?)
Does the authored dvd files on the pc (before burning) work fine with sound (i.e. is this a dvd playback issue)?
Does the burned dvd play on the pc? (i.e. could it be burning/disc media issue or DVD player issue?)
Please be more precise as to what is working or not working at each stage -
Thank you for your reply ! ! !Originally Posted by minidv2dvd
I attached word doc with prt sc's as a result of using GSpot.
prt%20sc.doc -
Thank you for your help !!!!!
No other software I used after vegas. I burned DVD using Nero Express (Nero 7 Ultra Express).Originally Posted by poisondeathray
File didn't have sound before burning the DVD. DVD player works and set up well. When I play this DVD, there is picture, but no sound.Originally Posted by poisondeathray
Yes, burned DVD shows movie on pc, but without sound.Originally Posted by poisondeathray
At the end of burning process, it gave me a message "completed successfully". -
Vegas Movie Studio HD 9.0 and Importing .avi files.
By empressofbees in forum Newbie / General discussionsReplies: 3Last Post: 17th Jan 2012, 17:45 -
Sony Vegas Movie Studio and Mp3 files. Do they mix?
By henrique_rp in forum Video ConversionReplies: 4Last Post: 9th Oct 2008, 22:21 -
making movie from many mepg/vob files
By volam in forum EditingReplies: 3Last Post: 10th Apr 2008, 11:33 -
Vegas Pro 8b Cannot Open MPG Files!! HELP :(
By 11233 in forum Newbie / General discussionsReplies: 3Last Post: 31st Jan 2008, 00:23 -
how to merge two .mpg movie files into one dvd file
By morefeus46 in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2007, 20:43
