I have an XviD video that I want to play on my standalone DVD player. I have a DivX compatible DVD player (Sony DVP-NS38). So I just burned the XviD video file on my DVD+RW and played it on my DVD player. The problem is the quality - it is sometimes blocky and not as good as on PC. Would it help if I would convert the XviD video to DivX?
EDIT: I know I could solve the problem by converting the avi to DVD but that would lose some quality, right? plus just burning the avi is much faster.
probably not. on the computer it's much smaller. as you increase the viewing size, the defects of low bitrate video and bad encoding become more apparent.
re-encoding would only cause the loss of more quality. -
I'm pretty sure the quality should be better. the bitrate is 2032 by the way, maybe that could be a problem for the DVD player..
The Xvid file may use optional MPEG 4 part 2 features that your player doesn't support. You can use something like AviRecomp to recompress with settings that won't cause problems. Any time you recompress with a lossy codec you will lose some quality. Use sufficient bitrate and the losses won't be too bad.
You can't fix this problem by converting, but you'll learn after you try. In fact there is no fix for this problem unless you can re-encode the original video yourself from the source and do a better job.
Xvid Playback Aspect Ratio Problem
By midders in forum Video ConversionReplies: 3Last Post: 1st Apr 2009, 14:24 -
Xvid AC3 file playback problem on Standalone DVD player
By kamol88 in forum Video ConversionReplies: 2Last Post: 21st Mar 2009, 03:38 -
Xvid and Divx playback problem on TV set
By herbapou in forum Media Center PC / MediaCentersReplies: 3Last Post: 7th Sep 2008, 12:17 -
Interlaced XViD playback on Standalone - Field Order Problem
By nbarzgar in forum Video ConversionReplies: 2Last Post: 13th Jul 2008, 07:04 -
Sound Problem During Playback (XVid, DVIX etc.)
By Pyrolisk in forum Newbie / General discussionsReplies: 5Last Post: 21st May 2008, 11:00
