Hi,
I've installed virtualdub 1.8.8 and the plugins pack so I can open FLVs and convert them to Divx.
I've also installed ffdshow rev. 3029 / 10-07-2009 and changed all disabled decoders to libavcodec.
Next I've opened the FLV (no problems there) and changed the decompressor to full processing mode, Divx. But when I save to avi I get
This forum suggests using a 1.6 version of virtualdub will solve it:The decompression codec cannot decompress to an RGB format. This is very unusual. Check that any "Force YUY2" options are not enabled in the codec's properties
http://www.teamliquid.net/forum/viewmessage.php?topic_id=37562
but I need 1.8 or later for FLV Input to work.
Another suggestion (link below) is to get the latest version of ffdshow and turn all decoders on, but I've already done this:
https://forum.videohelp.com/topic349206.html?highlight=decompression%20codec%20cannot%2...20rgb%20format
Any other suggestions?
Results 1 to 12 of 12
Set ffdshow to ouput RGB.
Start -> All Programs -> ffdshow -> VFW Configuration -> Decoder tab -> Output (left pane) -> enable the RGB options in the right pane.
It it still doesn't work try disabling all the YUV output options. If it still doesn't work ffdshow isn't being used, some other VFW FLV decoder is. -
Hi Jagabo
Still no joy.
I've tried outputting using the DivX codec and ffdshow (encoder set to xvid/divx) but the error still occurs.
I've turned of all YUV output options and changed the encoder setting to "force output colorspace: all RGB" to no avail.
Can you suggest how I can find out if ffdshow isn't being used an what else might be?
Thanks -
Interestingly I has TVersity codec pack installed. I uninstalled this then tried to load an FLV into VirtualDub and it said it doesn't find an appropriate codec. This would suggest VirtualDub was using a TVersity codec?
Anyway, I uninstalled ffdshow and reinstalled it configuring everything in VFW. The FLVs open again, but the RGB error still occurs
These seem to be VP6F. I've enabled everything - anything that was set to disabled is set to libavcodec. Still no joy.
I've resorted to using Free FLV Converter 6.5. It does the job, but I always prefer to use VirtualDub as it gives you full parameter control.
Thanks for your help jagabo. -
Its definately on in VFW, but what do you mean by the DirectShow section? "video decoder configuration"? If so, its on in there also.
Yes, Start -> All Programs -> ffdshow -> Video Decoder Configuration gets you to the Directshow settings. There are two main video handling libraries in Windows: VFW and DirectShow. Many editors use VFW (VirtualDub, for example). Most media players use DirectShow. Ffdshow has separate decoders for each.
I try to avoid installing and testing different video applications. Each application can install dozens of filters that are often incompatible with other applications. -
I'll be sticking to VirtualDub where possible. Its a fantastic program!
Virtual Dub: Unable to decompress avc1 file format
By s_joy09 in forum Video ConversionReplies: 29Last Post: 8th Oct 2013, 09:07 -
VirtualDub: Working with MKV & MP4 (frame jumps, RGB decompression etc.)
By pokepika in forum Video ConversionReplies: 4Last Post: 21st Sep 2011, 19:28 -
Use Techsmith codec (RGB Lossless) on Potplayer
By stranno in forum Newbie / General discussionsReplies: 1Last Post: 21st Jul 2011, 09:59 -
Unable to decompress your camera's image format cause a suitable codec is m
By cfairon in forum MacReplies: 2Last Post: 17th Jan 2011, 09:37 -
No audio decompressor could be found to decompress the source audio format.
By rocky12 in forum AudioReplies: 3Last Post: 1st Sep 2008, 00:59
