Having a Panasonic Viera LCD TV Model TX-L37S10B. It says that AVCHD and MPEG2 files can be played on an SD card inserted in the Card slot on the TV.
Can anyone please advise me how to convert MPEG2 files or convert to AVCHD so that they are able to play from the SD card placed in the TV.
I have tried MuiltiAVCHD but have had no luck with it. Is there any easier way of acheiving converting mpeg2 to AVCHD compliant to play from the SD card in the panasonic TV.
Is says it will play MPEG2 and AVCHD files has anyone else got a simular tv and got video files to play from the SD card.
Thanks in advance
Results 1 to 9 of 9
The file spec sould be detailed in the manual.
The manual seems hidden from Google.
AVCHD is typically 1440x1080i 25fps and 8-17Mb/s
HD MPeg2 can mean many things but it probably matches broadcast spec.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
lowtech,Originally Posted by LOWTECH
Did you try this forum?
http://multiforum.deanbg.com/viewforum.php?f=10&sid=6c892cffd7e6bef5d457d5bea76abcc6 -
Thanks for your replies....
Having used the only method of converting to AVCHD in site MultiAVCHD that I can find for panansonic SD viewing. It is not as easy or striaght foreward as I thought. Each conversion creates not a single file but several others ....
What I need is basic step by step guide of how to achieve what I now find is not just a simple task. The MulitiAVCHD guide is not that clear cut to me.
This type of conversion to a format needed to use it on my TV appears to very short in available info on the web in how to do it....as some reports of it being the way foreward.
I did get 2 files on a SD card to work, the first had a title and the 2nd did not, not much use if I ever manage to ever get 10 items on a SD card with only one title on the first item. Since then no luck in using the MulitAVCHD conversion system to convert other files.
With many of the lastest Panasonic TVs having this ability to view things stored on a much easier SD card system, getting it to work seems problematic to say the least.
Thanks again I will just have to keep trying. -
I'm not 100% sure, but I don't think MultiAVCHD actually performs a conversion of the video file, I think it only converts audio to AC3 and packages the video, unconverted, to the file structure needed for the Blu-ray spec.Originally Posted by LOWTECH
As to the actual video format conversion, the tool I find the most versatile, is SUPER http://www.erightsoft.org/GetFile.php?SUPERsetup.exe , similar for video conversion as what BeSweet is for audio.
Perhaps if you took your original files and truly converted the format to AVC/H264 with SUPER, and then packaged it with MultiAVCHD, you may get better results.
For large, HD content, however, SUPER is slow, thus why I sympathize and I too would prefer a more straightforward route to playing files on either Blu-ray palyer or as in your case, an sd card. A basic guide is here https://forum.videohelp.com/images/guides/p1608146/basicsuperguide.pdf
Wibo -
why is it that my multiavchd keep saying that my video is incompliant??? what should i do? i cant convert anything... please help.. thanks in advance.
I know that converting with super worked for a sony bravia with 720p res, 29.970fps, 2000kbps, mp4 container, h.264 codec, and mp3 audio@48khz/128kbps, baseline@3.1. It supports the same formats as the panasonic. But it never gave details on exactly what bitrate/profile etc.
Other programs I tried just wouldn't work for the tv even with the exact same settings. Seems like many models of tv's pre-2010 are very picky about format.
Just use super and test every combination until one works.
this is kind of a necro'd thread but this format thing bothered me for weeks until I got it working. -
How to watch videos on your Panasonic TV with a SD card
Samples videos on your Panasonic TV with a SD card
download archive
http://www.filefactory.com/file/cac5623/n/PRIVATE.rar
, unrar
and put everything in the root of the sd card
Voila Enjoy
Samples videos on your Panasonic TV with a SD card download archive http://www.filefactory.com/file/cd2bc22/n/KEN_BLOCK.GYMKHANA_TWO.zip , unzip and put everything in the directory PRIVATE in the root of the sd card -
download archive
http://www.filefactory.com/file/cd526c7/n/God_is_a_DJ_.zip
, unzip
Voila Enjoy
Help needed with .mts avchd panasonic files
By zapster in forum Video ConversionReplies: 10Last Post: 23rd Mar 2012, 11:08 -
Panasonic Viera TX50V20 TV will not play AVCHD
By dobien in forum Newbie / General discussionsReplies: 5Last Post: 19th Jul 2011, 10:47 -
Converting file to play on sony cybershot dsc tx1 help needed please
By arcalis in forum DVD RippingReplies: 0Last Post: 20th Dec 2010, 12:53 -
Help needed with Editing and Authoring AVCHD
By chrisdhall in forum EditingReplies: 2Last Post: 20th Apr 2010, 04:39 -
Panasonic AVCHD - WHAT?
By joeypowell in forum Video ConversionReplies: 4Last Post: 19th May 2008, 00:17
