Hey all... i have a collection of about 100 avi files and understand i can play them on a home dvd player that supports Divx...my question is do i just save these files to a dvd and that will allow them to play or do i use a special software for burning them to a DVD? If i do, what is the best. Everytime i search, it's all for converting and not just writing the files. I have been working with DVD files for years but never had to deal with avi files.
thanks!
Exactly.Originally Posted by tlrbjc
Dumping the AVI files.....as DATA....to a DVD.
Does your DVD player support playing AVI files as data from a DVD? -
first you might want to check whether or not the "avi" files are in a supported dixv format. avi is just a general term for a container - "audio visual interleave" and can have many different formats inside it that are not at all playable in a divx machine.
use mediainfo or gspot on the files to check them. -
And to add a bit to minidv2dvd's excellent advice, note that these divx-capable dvd players can be fussy about the particular parameters that they can handle (e.g. bitrate, resolution, audio parameters, etc.). So, even if those avi files are divx, that by itself does not guarantee playability. You'll just have to try it and see -- or check the manufacturer's documentation, but nobody ever does that.
Even with my Oppo 980 (probably better than most for such files), I've gotten very mixed results with this: often, the very same files will play from a thumb drive, but won't play from a DVD. And I don't know why that would be.Originally Posted by hech54Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
Just a guess that could be wrong - maybe the Oppo doesn't support UDF versions above 1.02 on DVD and your DVD is burned using some other more recent UDF version. UDF won't be used when playing from a thumb drive.Originally Posted by Seeker47
Simple question....... what is the best way to join AVI files
By True Colors in forum Newbie / General discussionsReplies: 3Last Post: 24th Apr 2010, 21:22 -
Noob question about converting ripped files to AVI
By gingerman74 in forum Video ConversionReplies: 4Last Post: 20th Mar 2010, 23:39 -
A question related to sub files and resized avi with AGK
By loninappleton in forum Newbie / General discussionsReplies: 7Last Post: 19th Jul 2009, 22:35 -
For VOB files to AVI, I use avi.net . . Question
By nhbfan12345 in forum DVD RippingReplies: 4Last Post: 10th Sep 2008, 23:02 -
I have a question about burning avi files to dvd...
By amcardwell in forum Newbie / General discussionsReplies: 4Last Post: 22nd Apr 2008, 15:07
