I have a original Blu Ray movie (the replacement killers) which i have ripped to my Harddrive using ANYDVD HD. I have then converted it using BD Rebuilder (setting are as follows:- movie only)all was fine until i tried to play the movie abck on my PC and PS3. The picture is fine but there is no sound. Can someone please tell me where i am going wrong.
Moving you to our blu-ray to blu-ray backup forum.
Recheck the audio settings in bdrebuilder again. Try keep a different audio track then now, like standard dolby digital 5.1 instead of for example dts hd.. -
never mind
ocgw
peacei7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
https://forum.videohelp.com/topic368691.html -
ocgw probably did write something, but may have changed it (maybe it was what Baldrick already suggested?) You can't delete your posts, so he did the next best thing. No need to get snippy.
Do you have a DTS decoder? You probably have the DTS audio and it needs to be run through an external amp. You may need to re-create the disc if you do not have a decoder.
Here is a guide. Make sure to select the multi-channel ac3 audio when you make the disc (usually the second audio). The first is usually (almost always) DTS. -
I was asking you a question but when I reread your post it answered it for me lolOriginally Posted by rayray1
I have read a lot of complaints after someone makes a movie only backup w/ BD Rebuilder after it has been saved as movie only w/ TsMuxer, some ppl report more consistant results when they start out w/ Clown BD (demux's w/ eac3to)
TsMuxer has been my fav program for processing BD's as long as I have been saving movies for HTPC only, but as I start to back up to disc for playback in a stand alone player things have changed
See, you want to preserve as many of the "flags" as possible for more consistant playback over a broad range of hardware and software
BdRebuilder has a great x264 encoder but doesn't preserve those "flags". or "markers" in movie only mode
I have had problems too, so w/ the high quality output of BD Rebuilder @ high compression I am rethinking my strategy
When I know a movie is going to be too big to backup to a single layer disc I am going to rip the whole movie, run it thru BD Rebuilder as whole movie, THEN remux w/ TsMuxeR or Clown BD do get rid of garbage I don't want
Give that a try
ocgw
Burning Blu-ray Data Disc with ImgBurn.
By bbanderic in forum DVD & Blu-ray WritersReplies: 25Last Post: 11th Oct 2015, 13:21 -
Blu Cloner Blu Ray Backup
By pepegot1 in forum Authoring (Blu-ray)Replies: 8Last Post: 24th Apr 2011, 22:26 -
AnyDVD HD and ImgBurn Blu-ray/DVD Ripping.
By bbanderic in forum Blu-ray RippingReplies: 3Last Post: 3rd Feb 2010, 07:13 -
Blu-ray backup to DVD9???
By blusky1 in forum Blu-ray RippingReplies: 25Last Post: 2nd Jan 2010, 23:40 -
Burnt Blu-ray not playing on PS3
By cyberpimp16 in forum Blu-ray RippingReplies: 1Last Post: 14th May 2009, 12:53
