  1. Member SE14man's Avatar
    Jul 2005
    Queensland
    The past year o have had 3 options when i boot of what OS to use and it only appears for like 2 seconds o i quickly have to select the bottom option....
    How do i get rid of these and when i do get rid of them, how can i be sure im getting rid of the appropriate ones so i dont screw my windows up?
    Thanks fellas.
  2. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    This is set in the file boot.ini, probably in c:\
    You can edit it directly in notepad, or you can use
    msconfig (Start/run and type "msconfig")
    In that you can see and change the timeout, and change the default OS.
    http://vlaurie.com/computers2/Articles/bootini.htm
    http://support.microsoft.com/kb/289022
