Question: what program can I use to create reverse loops without affecting the size, aspect ration, and quality of the videos?
I have some small video clips that I want to play around with, and using Premiere CS4, I cannot get it to output the 5MB file without blowing it up to 400MB. I tried different settings and it's always the same. The original aspect ratio of 640x352 is now 740x480 but the picture looks smaller on my monitor.
I just want something that works without changing the original aspect ration and size of the file.
Thanks for any help.
cs4 is an editor for dv hdv and other un or lightly compressed source material. it doesn't really like working with output type compressed formats but will usually accept them grudgingly. did you try setting the project properties to whatever the source material format is?
Yes, I tried various settings from custom aspect ratio to codecs, but the results were large file sizes and smaller pictures. Is there a program that work well with avi files that allows me to add effects like reverse loop?Originally Posted by minidv2dvd
If you want 640x352, set your project to 640x352.
It will need to be decompressed.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Originally Posted by edDV
When I first start up Premiere CS4, there are two pop up windows asking for various presets. One of those windows has the option to enter a custom aspect ratio, and I entered 640x352, but the final product still had a higher aspect ratio. Maybe I am doing something wrong. Can you show where I need to input this preset? -
Did you specify square pixels in the New Project menu?Originally Posted by J-E-T-S
I don't have CS4 but I may be able to simulate if nobody else responds.Recommends: Kiva.org - Loans that change lives.
Premiere Pro CS4 CROP feature
By CharlesLinquist in forum Newbie / General discussionsReplies: 2Last Post: 24th Jul 2010, 20:53 -
Need help on premiere pro CS4
By george2005 in forum EditingReplies: 5Last Post: 27th Mar 2010, 05:42 -
Adobe Premiere Pro CS4 Cannot Import .mp4 File
By spike32 in forum EditingReplies: 5Last Post: 19th Jan 2010, 09:15 -
Viewing Problem in CS4 Premiere Pro
By carfyx in forum MacReplies: 2Last Post: 18th Jan 2010, 22:20 -
Should I get Adobe Premiere Pro CS4? - Upgrade from Pro 1.5
By vid83 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Feb 2009, 18:10
