Hello,
I used The Film Machine with cce at 4passes to encode a HD video file of mine to DVD, but it ended up just a little too big to burn off. 108% according to imgburn.
I can probably shrink it down with DVDShrink, but, I'd like to know the more "professional" method(s). Since it's a high quality encode. I did however try degrading the credits in DVDShrink but it wasn't enough.
Thanks.
	you already lost the hd part of it when you encoded it to dvd you went from 1080p or 720p to 480p. so shrinking it that last little bit(.08%) with dvdshrink shouldn't be noticeable.myself i would encode it to blu-ray with one of the tools for hd. either you have a blu-ray player now, or else you'll probably eventually get one at some time. member since 1843
	Yes, I knew that thanks.  Was 720p btw. Was 720p btw.
 If I had a HD-DVD/bluray player let alone a HDTV then yes, I'd do that and wouldn't be converting to Standard DVD.
	DVD Shrink uses a requantizing algorithm, so you won't suffer noticeable quality loss for an 8% filesize reduction. You've already done a transcode (and to a much lower resolution, at that), so being fussy about quality at this point makes little sense. Just Shrink that puppy and be done. Requantizing is a very fast operation (as opposed to transcoding), so you can get results quickly.
  How to copy DVD9 with subtitle & Burn it in DVD-/+R or DVD9By prithvi in forum Newbie / General discussionsReplies: 15Last Post: 19th May 2010, 12:37
  Video won't fit on dvdBy chevyfever in forum Video ConversionReplies: 5Last Post: 6th Nov 2009, 08:50
  USB stick won't fit in printerBy csaag in forum ComputerReplies: 4Last Post: 25th Aug 2009, 21:54
  DVD9 to DVD9 2 angles layer break problemBy JoeBolden in forum DVD RippingReplies: 4Last Post: 14th Jul 2009, 20:17
  why won't my avi fit on a dvd-rBy bigwheels103 in forum Newbie / General discussionsReplies: 3Last Post: 24th Oct 2007, 22:08
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
