    Jul 2009
    Hi,
    I am really new to ripping dvd files that I want to put on my iPhone, so yesterday I was downloading free software to my iMac, (10.5.7),
    and was trying out different software to use and not really reading instructions, just clicking buttons to see what worked.
    I clicked "ok" to download additional software called "3ivx" and clicked "ok" on a compatible app to load. Now when I try to rip a dvd of LOST, (I never saw it and trying to catch up with friends) I keep getting this over my files, no matter what software I use, so how do I get rid of this?
    Please help, I will really appreciate it.
    Thank you,
    Gary
  2. uninstall 3ivx
    Go to control panel then
    Add or Remove programs then
    Remove 3ivx
    And dont give me excuses "I've only got a Mac" :HandBag:
    The electronic components of the power part adopted a lot of Rubycons.
  3. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    This might help: http://forums.3ivx.com/index.php?showtopic=86578
    Never bothered with 3ivx on my iBook, so I'm probably not going to be able to help, much.
    Jul 2009
    Thank you so much, Ai, the forum was very useful and solved my problem. Thank you to everyone for your suggestions!
    Peace,
    Gary
  5. Banned
    Freedonia
    I don't keep up with Mac based video solutions as I use a PC for that, but the folks at Divx (http://www.divx.com) do have a commercial encoding solution for Mac that's not expensive. By the way, I work with a bunch of Mac fanboys and all I ever hear from them is stuff like "Why don't you just use Handbrake?" (it costs money too) with puzzled looks as to why anyone would want to use anything else.
  6. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    jman98: Huh? As far as I know, Handbrake has always been free - it's open-source, and has versions available for Macs, Windows and Linux.
    I'm not one of the people who recommend it - not that it's bad, I just don't use it.
  7. I actaully like handbrake....just wish they'd fix the 12bytes problem.
    Originally Posted by jagabo
