  1. Hi
    This is just plain madness. I took some video Footage on my Sony Cybershot Camera and for some reason Quicktime Pro cannot edit the video footage. Can anyone here advise me why this is happening.
    *** MediaInfo Mac // Plain text file report
    General / Container Stream # 1
    Total Video Streams for this File -> 1
    Total Audio Streams for this File -> 1
    Video Codecs Used -> MPEG-1 Video
    Audio Codecs Used -> MPEG-1 Audio layer 2
    File Format -> MPEG-PS
    Play Time -> 27mn 25s
    Total File Size -> 571 MiB
    Total Stream BitRate -> 2 913 Kbps
    Video Stream # 1
    Codec (Human Name) -> MPEG Video
    Frame Width -> 640 pixels
    Frame Height -> 480 pixels
    Frame Rate -> 25.000 fps
    Total Frames -> 41146
    Display Aspect Ratio -> 4/3
    Scan Type -> Progressive
    Codec Settings (Matrix) -> Default
    Video Stream Length -> 27mn 25s 840ms
    Video Stream BitRate -> 2 647 Kbps
    Video Stream BitRate Mode -> VBR
    Audio Stream # 1
    Codec -> MPEG Audio
    Audio Stream Length -> 27mn 25s 560ms
    Audio Stream BitRate -> 64.0 Kbps
    Audio Stream BitRate Mode -> CBR
    Number of Audio Channels -> 1
    Sampling Rate -> 32.0 KHz
    Bit Depth -> 16 bits
    Audio Stream Delay -> 110ms
  2. a couple things. try to be more patient, there are only 4 registered users online right now and it could be none of us are mac users. which brings up the second suggestion. post mac questions in the mac forum and you have a better chance of a mac user noticing your post.
    it is a strange size for mpeg-1 and vbr to boot. usually it's seen as 352x240 cbr and mainly used for vcds.
    convert to a different format, maybe a lossless intermediate?
