I have read the profile for the SONY DVP-S336 and for a while it has stated that SVCD is NOT supported. Recently someone stated that:
But many other posts state the opposite.Plays SVCD's produced with TMPGEnc template
and burnt with Ulead DVD MovieFactory yet to
check Nero
Didn't support menu just played tracks
see notes page 22
of the manual that came with it (Australia)
Player displays Super VCD in the top right corner
as disc starts.
Is this a red herring or has anybody elso had any luck authoring an SVCD which works on this player - and how?
I have tried a short clip using TMPGenc PAL SVCD template and also XSVCD (parameters unknown) burnt using NERO - both failures...
They may be using the header hack, meaning they just put a VCD header on a SVCD file. Do so at your own risk, since compatability is a crap shoot.
Try this:
1. Open TMPGenc
2. Load Video
3. Load Audio
4. Load Template (SVCD)
5. Following Encode.
6. File
7. MPEG Tools
8. Merge & Cut
9. Add Audio/Video File
10. Choose MPEG 1 (non-standard)
11. Save as a different file name.
12. Open NERO
13. Choose VCD
14. Uncheck standard Compliant
15. Drag into Nero
16. Write CD
If that doesn't work. Substitute step 8 with demultiplex then multiplex.
Sony dvp-sr100
By deyangg in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Oct 2011, 04:54 -
My Sony DVD player SONY DVP- NS718 H
By samyer in forum Newbie / General discussionsReplies: 1Last Post: 3rd Feb 2010, 00:56 -
Sony dvp sr-100
By munskin in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Aug 2009, 12:04 -
Sony DVP-FX720
By haidee in forum Portable VideoReplies: 0Last Post: 3rd Jan 2009, 09:11 -
Sony dvp-s336 and DTS problem
By ManWithaPlan in forum DVD & Blu-ray PlayersReplies: 5Last Post: 17th May 2007, 14:28
