So, pretty self explanitory.
I have my XBOX hooked up to my Acer 22" which has only 2 connections on the back, DVI and VGA
and of course my Xbox takes up the VGA, while DVI is monitor.
How could i capture my gameplay on my 360 and save it to my computer?
possible? expensive? eithe way i'd love to know.
Any help would be GREATLY appreciated!
You need a capture card that you can connect the Xbox to, and use this. The monitor or TV side of things really has no bearing, as neither are are actually part of the capture process, but just a method of seeing what is happening.
One thing to note : many people report issues trying to capture from consoles. These issues range from the odd output methods of some games (PAL60, for example), and the delay introduced by having a capture card in the mix can make actual game play difficult. Also, you would be playing in the preview window, not fullscreen.
If you want to play fullscreen then I would suggest some form of splitter that would allow you to connect to a TV for gameplay, and also to your computer (and a capture card - you would still need one of those) for capture. This would remove the delay issue and allow you to play more comfortablyRead my blog here.
In your particular configuration, there is no easy way to capture VGA.
http://www.kiva.org/about
Help capturing xbox 360 video when xbox is connected to monitor with vga
By laldabomb8 in forum Capturing and VCRReplies: 0Last Post: 23rd Jul 2010, 02:05 -
Connecting Xbox 360 to PC monitor
By man1mal in forum AudioReplies: 0Last Post: 14th Jun 2010, 09:21 -
xbox 360 capture video and audio while playing on pc monitor
By josh123 in forum Newbie / General discussionsReplies: 0Last Post: 5th Jun 2010, 02:51 -
Xbox 360(elite)/PS3 video capture help. Monitor no components!
By DonkeyKongStar in forum Capturing and VCRReplies: 0Last Post: 11th Jul 2009, 15:09 -
Xbox 360 Capturing from PC monitor
By U1337 in forum Capturing and VCRReplies: 2Last Post: 28th Jul 2008, 01:37
