I was having this problem for a long time now...
I recently expanded my memory to fix this however, while rendering my computer shuts off without any warning
Every single time![]()
is it because I have XP? Does anyone know how to solve this problem??
Usually this indicates an issue with overheating. A few simple steps to try
1. Take the side off the case and carefully blow any dust out. If you use a compressed air canister make sure you stop the cooling fans on the gfx card and CPU turning or you can damage them with the force.
2. Leave the side off the case, and use a small house fan to blow cool air through the case. Run your render and see if it fails. If it does not, then you have your solution - better cooling.
3. If the render continues to fail, check the event logs for failure messages or anything that hints at the issue.
Rendering is very CPU intense, and will usually work the CPU at close to 100% for the duration. If your cooling isn't up to scratch the system will shut itself down to avoid doing damage to components once the temperature gets to a certain level.Read my blog here.
Sony Vegas Pro mpeg rendering size larger than movie studio
By bbbbbbb45 in forum Newbie / General discussionsReplies: 2Last Post: 17th Jan 2012, 13:31 -
sony vegas pro 8 rendering wont render video just audio and text
By bahlue18 in forum EditingReplies: 6Last Post: 12th Apr 2011, 08:31 -
Sony Vegas pro 9. Rendering Black screen
By jolehoz in forum EditingReplies: 0Last Post: 15th Nov 2010, 12:02 -
Rendering MPEG 2 in SONY VEGAS PRO 9
By sfalcon in forum AudioReplies: 1Last Post: 21st Feb 2010, 17:07 -
Basic Rendering Settings for DVD using Sony Vegas Pro 8
By JerryRecords in forum EditingReplies: 1Last Post: 2nd Aug 2009, 15:13
