Okay, I understand that rough portions of the vhs videos I capture will drop frames. But I'm wondering if my Pyro ADS box is just not that good since it drops frames a pci card or dvd recorder doesn't. The other thing is that when it drops frames, the video has all this extra black space put in between. It might be 3 seconds that dropped but a minute of black frames appears in the video clip. So capturing a clip that was 2:40 takes up 6 minutes on the Vegas timeline, half just total black empty frames. And it's a real pain to cut out the black space, move the rest together, splice in the dropped frames that captured fine on a dvd recorder. So is this common with DV capture boxes?
And does anybody know what the dip switches on the back do. They're really tiny that have a green coating over them with an up or down position.
Results 1 to 12 of 12
I don't see relock that bad on my DV camcorders or Canopus ADVC. It could be your capture software. Try WinDV.
The dip switch modes should be in the manual.
Usually they set modes like
NTSC vs PAL
Audio Sample Rate
Start defaults
Black level (7.5IRE vs. zero)Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
If your tape has gaps, sync is lost. That will usually cause capture to stop. If it keeps going, the next bit of video needs to be resynchronized by the Pyro and capture software.
WinDV is safe from this web site.
http://windv.mourek.cz/
Here is a tutorial
http://www.windowsmoviemakers.net/PapaJohn/61/WinDV.aspxRecommends: Kiva.org - Loans that change lives.
The tape doesn't have gaps, just video that was edited through a vcr. (So it has the rainbow line) I know that is prone to drop but that doesn't excuse the black space in between. Nor does it explain why my dvd recorder (and PCI card) has no problem with those parts.
So what I'm really trying to understand is what causes all that black space where frames drop. Has this been observed before by anyone else? Is there a way to set it to not do that. Is it only found in the Pyro or can that happen with any DV capture that drops frames.
I got the Pyro in 2003, would a new Canopus likely do better? -
I've never seen that.
sounds like somethings wrong with the ADS...your computer looks pretty old, too...perhaps a combo of both...did it do this in 2003? how much to have ADS look at it? pick up a cheap ADVC 55?
Read the PapaJohn tutorial for setups. You put the path and capture file name in the "Capt. file:" block.
DV capture (stream to file) has very low CPU load. I used to do it no problem on a PII 300MHz.Recommends: Kiva.org - Loans that change lives.
Could you give more details on how to do that? How do I look up the file path name.
As for my computer, it was custom built but I updated it a few years ago. It's really fast, boots up in seconds. I think the capture box is somewhat like a bottleneck, it just can't handle data even though the rest of the computer can. I'm thinking the capture box could be due for a replacement but I want to get some confirmation if possible. -
Test it on your cable box if you think the VCR is the problem.
Otherwise follow the tutorial.Recommends: Kiva.org - Loans that change lives.
How can I test it on a cable box. I'm really confused. Plus they're on two separate floors.
I'm trying to follow the tutorial but I don't know how to find the path and capture file name. The imput is through a firewire cable but it's not listed as a drive (like F) under my compter. I don't think my vhs vcr is the problem anyways.
Analog capture with Studio Pinnacle 15HD, Dropped frames?
By rivrbyte in forum Capturing and VCRReplies: 2Last Post: 31st Dec 2011, 16:00 -
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
Pleas Help with intensity pro capture dropped frames issue
By jub2k3 in forum Capturing and VCRReplies: 14Last Post: 18th Jun 2010, 13:38 -
Neither Vegas Video nor WinDV show dropped frames count after capture
By korey99 in forum Capturing and VCRReplies: 13Last Post: 9th Apr 2009, 17:25 -
Jumpy playback, dropped frames during capture, CPU pegged to 100%
By tylerz in forum Newbie / General discussionsReplies: 7Last Post: 24th Jul 2007, 18:09
