Results 1 to 9 of 9
    May 2006
    I'm wondering if there is a way that I can run a bunch of files thru Virtual Dub using avisynth?
    Here is the code that I use:
    Load_Stdcall_Plugin("C:\Program Files\AviSynth 2.5\plugins\yadif.dll")
    AVISource("C:\Documents and Settings\bsuska\Desktop\global relief for homepage.avi")
    Yadif(mode=0,order=0) #bottom field first
    Crop(8,12,-8,-12)
    LanczosResize(224,168)
    In Virtual Dub it seems like I can only process one video at a time.
    Thanks.
  2. 1 script = 1 video
    May 2006
    Any programs that will run multiple scripts automatically?
  4. Member Safesurfer's Avatar
    Mar 2004
    What about job control in VirtualDub, you will still have to add the jobs one at a time, but it will then run them as a batch?
    "Just another sheep boy, duck call, swan
    song, idiot son of donkey kong - Julian Cope"
    May 2006
    Job control brings up a dialogue box that won't allow me to open my .avs file. I can't get the avisynth code in...
  6. Member Safesurfer's Avatar
    Mar 2004
    No, you open the avs script as a normal file, and do the setup for saving the file. Job control is accessed when you use Save as AVI, there is a check box at the bottom of the dialog which enables you to save to the job queue. Once you've set up all of your scripts, you use job control to run them all.
  7. dude is funny somewhat ^^
    do like safesurfer say
    your script contain a mistake imo
    assuming your .avi is interlaced bottom field first , ntsc 29.970 and encoded in the yv12 or yuy2 color space, you should write:
    v=avisource("C:\Documents and Settings\bsuska\Desktop\global relief for homepage.avi")
    a=wavsource("C:\Documents and Settings\bsuska\Desktop\global relief for homepage.wav")
    audiodub(v,a)
    assumefps(29.970,true)
    AssumeBFF()
    Yadif(order=0, mode=0)
    Crop(8,12,-8,-12)
    Jul 2009
    Spain
    Originally Posted by themaster1
    AssumeBFF()
    AssumeBFF() is unnecessary since order=0 explicitly tells Yadif to use bottom field first.
    May 2006
    I guess your code change confuses me. Usually the file that I'm transcoding is a Huff avi that has sound and video all in one avi.
