hi
every time im takin' couple of film-strips and dragging them to convertxtodvd
in order to be showed up in my dvd player as dvdr
so when im playing it in the dvd, picking a film and the film has finish play. it always showing the window
whether to back to the menu or to play the next film.
unless couple of seconds before the film is over i press the Skip buttom on the remote control.
only then it is showing the next film
and what i want it to do is that it will automatically play the next film-strip while the first has finish playing it. without asking me whether to play the next or to go back to the menu
does anyone know how to do that?
10x
if I am understanding you correctly, you want to do this:
open convertx and click on the settings tab. Next click on the "dvd menus" tab
you want to CHECK the following:
1. play titles one after the other
MAKE SURE THIS IS NOT CHECKED:
return to title menu after titleset playback
now after one item plays it should go to the next item without going back to the root menu--enjoy -
10x 4 comment but this 1 i already know
the problem is when im doing it what happen's that when im inserting the dvd its automatically playing all of them 1 by 1 without showing the menu at all
what i want it to do that it will show me the menu but when im choosing 1 it will play the second when 1 has finished
this is what im markin':
http://i27.tinypic.com/2q9djlk.jpg
and where is this option of:
"return to title menu after titleset playback"
10x -
what version are you running because I never saw a screen look like that??
at any rate
From your picture you want to UN-check "skip root menu" This will bring up your menu when you put in the dvd and now it should work the way you want it to. Keep the play videos one after the other CHECKED
It will first to go the menu, then when you select your play item it will now go to the next item and should not go to the menu
Help deinterlacing/IVTC'ing VHS material converted years ago from film
By Mini-Me in forum Video ConversionReplies: 25Last Post: 4th May 2015, 14:46 -
horizontal strips in the video
By 3thman in forum Video ConversionReplies: 10Last Post: 9th Sep 2009, 10:31 -
Hacker Strips DRM From Netflix Movies
By MeDiCo_BrUjO in forum Off topicReplies: 17Last Post: 9th Sep 2007, 19:16 -
29.976 to 25fps (removing pulldown from a NTSC converted PAL film transfer)
By ecc in forum Video ConversionReplies: 25Last Post: 15th Jul 2007, 23:31 -
Converted analog film movies to BMP/JPG: now to AVI and then DVD
By Wimpie44 in forum Newbie / General discussionsReplies: 13Last Post: 1st Jul 2007, 13:47
