No matter what I do all my captures look blocky and this is before I convert it to mpeg!!!! I alway use huffuy or uncommpressed rgb but it always looks blocky. I am using vdub to capture. Does anyone knowthe solution to my problems? It loooks alright before I try to capture and view it on my tv card program.
Baker
What resolution are you capturing?
What program are you displaying it with? (maybe the problem isn't your capture but your display...and how big are you displaying it?) -
OK, never seen anything like it, and can't imagine how it can be something you could be doing wrong, to get that effect. Maybe try reinstalling VDUB (but I guess you've tried that already).
If you haven't already, try capturing at 1/2 or 1/4 resolution to see if it is bandwidth related in anyway. Check that you are capturing at the correct frame rate (maybe it got changed somewhere by accident). And try capturing without displaying to see if it is some display-while-capturing problem (as I have read about some with the BT chips). Also, check that you don't have the noise reduction turned on at capture and set to some ridiculously high value......now I think I'm realy out of ideas!
Good luck
Blocky MKVs
By romanticwarrior in forum Authoring (Blu-ray)Replies: 4Last Post: 2nd Dec 2010, 16:06 -
FFMPEG too blocky
By IMC in forum Video ConversionReplies: 4Last Post: 3rd May 2009, 17:00 -
can you help ...ulead...mpeg... blocky
By newbie44 in forum Newbie / General discussionsReplies: 0Last Post: 15th Jan 2008, 07:43 -
Blocky or Boxy?
By jethroangel in forum EditingReplies: 2Last Post: 10th Oct 2007, 22:18 -
QT DV blocky playback
By Fifou in forum Video ConversionReplies: 5Last Post: 7th Aug 2007, 11:56
