When i am trying to convert some video get error
Full logCode:Decoder (codec id 86056) not found for input stream #0.0
Faad and faac installed with ./configure --disable-drm --disable-mpeg4ip and ./configure --disable-mp4v2Code:ffmpeg -i tiffany_r_1920.wmv -ar 22050 -sameq -y 1.flv FFmpeg version SVN-r19436, Copyright (c) 2000-2009 Fabrice Bellard, et al. configuration: --enable-gpl --enable-libfaac --enable-libfaad --enable-nonfree libavutil 50. 3. 0 / 50. 3. 0 libavcodec 52.32. 0 / 52.32. 0 libavformat 52.36. 0 / 52.36. 0 libavdevice 52. 2. 0 / 52. 2. 0 libswscale 0. 7. 1 / 0. 7. 1 built on Jul 15 2009 17:43:30, gcc: 4.4.0 20090506 (Red Hat 4.4.0-4) Seems stream 1 codec frame rate differs from container frame rate: 1000.00 (1000/1) -> 29.97 (30000/1001) Input #0, asf, from 'tiffany_r_1920.wmv': Duration: 00:26:48.11, start: 8.000000, bitrate: 8237 kb/s Stream #0.0(eng): Audio: 0x0162, 48000 Hz, 2 channels, s16, 192 kb/s Stream #0.1(eng): Video: vc1, yuv420p, 1920x1080, 7997 kb/s, 29.97 tbr, 1k tbn, 1k tbc Output #0, flv, to '1.flv': Stream #0.0(eng): Video: flv, yuv420p, 1920x1080, q=2-31, 200 kb/s, 90k tbn, 29.97 tbc Stream #0.1(eng): Audio: adpcm_swf, 22050 Hz, 2 channels, s16, 64 kb/s Stream mapping: Stream #0.1 -> #0.0 Stream #0.0 -> #0.1 Decoder (codec id 86056) not found for input stream #0.0
ffmpeg installed with ./configure --enable-gpl --enable-libfaac --enable-libfaad --enable-nonfree
Please help!
not a linux user but i'd guess it doesn't come with a wmv codec installed. you probably need to get a windows media codec.
Also, are you sure the .wmv doesn't have DRM?
Codec problem in ASF/wmv file (wvc1)
By ezzeee1 in forum EditingReplies: 7Last Post: 25th Feb 2011, 20:16 -
Problem converting mov to flv with ffmpeg
By zigune in forum Video ConversionReplies: 8Last Post: 15th Jul 2009, 02:03 -
Windows (WMV) Codec/Driver Problem?
By hech54 in forum ComputerReplies: 2Last Post: 23rd Apr 2009, 08:40 -
MEncoder Crash on WMV & Possible Codec Problem!?!?
By gonwk in forum Video ConversionReplies: 0Last Post: 8th Mar 2009, 19:15 -
WMV codec problem
By coasterfreak212 in forum Portable VideoReplies: 7Last Post: 24th Jan 2008, 11:34
