Hi,
I received several of DVD-Rs that when I try to play on my both DVD players I receive a disk error message. I looked at the disk in windows explorer and did find a VIDEO_TS folder and was able to double click on the .VOB file and play it using Nero Essentials. I ran Nero Info Tool on the disk and it says it is NTSC 4:3 (MPEG 2, 720 x 480) so it is not in the PAL format. I also I just checked one of the disks with IMgBurn. (See below)
The region says all and I'm in the US so that shoudn't be a problem. I'm wondering if the disks were never finalized. If so, can I somehow salvage the files and burn a DVD-R that can be viewed on a DVD player using ImgBurn or DVD Decryptor or perhaps Nero?
Thanks,
Here is ImgBurn report on it:
PIONEER DVD-RW DVR-116D 1.09 (ATA)
Current Profile: DVD-ROM
Disc Information:
Status: Complete
Erasable: No
Sessions: 1
Sectors: 1,821,104
Time: 404:43:29 (MM:SS:FF)
TOC Information:
Session 1... (LBA: 0)
-> Track 01 (Mode 1, LBA: 0 - 1821103)
-> LeadOut (LBA: 1821104)
Track Information:
Session 1...
-> Track 01 (LTSA: 0, TS: 1821104, LRA: 1821103)
Pre-recorded Information:
Manufacturer ID: SONY16D1
Recording Management Area Information:
TOSHIBA 1/04 432R061106 ODD-DVD SD-R5272
Physical Format Information (Last Recorded):
Disc ID: 0@P-!-00
Book Type: DVD-R
Part Version: 5
Disc Size: 120mm
Maximum Read Rate: 10.08Mbps
Number of Layers: 1
Track Path: Parallel Track Path (PTP)
Linear Density: 0.267 um/bit
Track Density: 0.74 um/track
First Physical Sector of Data Area: 196,608
Last Physical Sector of Data Area: 2,017,711
Last Physical Sector in Layer 0: 0
if they weren't finalized you most likely wouldn't be able to read anything on them. you might try copying the video_ts folder to your hard drive and letting imgburn build and burn a new dvdr for you from a brand you know plays on your standalone.
and welcome to the forum. -
Thank you very much, I'll give it a try. In ImgBurn which file should I click on? There is an .IFO file, a couple of .BUP files and several .VOB files.Originally Posted by minidv2dvd
Also, I don't think I can burn yet, correct? It looks like I am being directed to the build mode. -
I did get it to work with Img Burn by copying the VIDEO_TS folder and using the Build mode.
I do have one other DVD-R that has a VIDEO_RM folder as well as a VIDEO_TS folder. Do I only need to copy the VIDEO_TS folder?
Also, would this work using a regular disk copy procedure in ImgBurn?
Pulling data from an unfinalized DVD
By sahaba in forum DVD RippingReplies: 37Last Post: 18th Oct 2017, 07:09 -
Cannot rip unfinalized DVD
By rmcluesman in forum DVD RippingReplies: 1Last Post: 6th May 2011, 13:46 -
Pulling data from disk (DVD+R)
By Antares in forum DVD RippingReplies: 7Last Post: 10th Apr 2011, 08:28 -
Recovering Data from an Unfinalized disc with ISO Buster
By socool135 in forum Authoring (DVD)Replies: 13Last Post: 19th Jun 2007, 23:58 -
By socool135 in forum MediaReplies: 1Last Post: 17th Jun 2007, 03:21
