Ok guess i ll just play with it some more, i ll try running it with the panes showing the videos maybe so long as the status bars don t stop its working ok, first i have to let dub do its thingy that i save video correct ?
sometimes it says i don t have admin prevledges and it won t save it but i am the only user, this is my pc so how do i fix that, wonder how that got goofed up - byeee later . . maybe all is ok even if the video never looks right must try that . .
Results 31 to 38 of 38
Ok a little mixed up i can t watch V D do its thing but i can preview it and then let Dub fix the contrast and brighten etc and then i save the video right its after dub not before; hopefully then i ll have 2 copies one before dub and after dub and their should be a big difference between the two right ? Then i can used Convert X to burn to a dvd ? ? do i have it right finally, did i miss anything - thanks a bunch . . . must see if it locks up don t think so - later can t wait to see the difference . .
1: Files downloaded from the net must be completely downloaded
2: You then need to determine what the file is exactly in order to know which application is the most appropriate ... some aren't.
Use gspot or mediainfo on the video to determine what it is ... the term "avi" dose not give enough information to solve problems.
In virtualdub, in order to apply video filters the video requires recompression ... audio may be "direct stream copy" as this is not changed. -
Ok trying a b and white Avi video hope to increase contrast and brightness but no preview running so hope its working; once it finishs i would then have two copies of that or would it be just one the dub version and then how do i save the dub copy in my dvd so i can burn in the next day and would i have to use convert X before i burn it - thanks
Ok noticed that Dub won t run wmv or video_TS videos can i fix that or use other software to improve the view. Seems like dub is mostly for Avi and videos close to that, can t be sure all works until after dub has finshed right ? then save to a folder as usual right - and then watch it and see if its improve right ? - later and whats this weird error about " MPEG import filter invalid pack at position three bit not set possibly MPEG - 2 stream " ! ? bye for now . .
You can add plugins to get wmv and vob/mpeg2 import support, http://home.comcast.net/~fcchandler/index.html
Ok how do i create a folder never done that before using vista HP
In Explorer: Go to the folder where you want to create a new (sub)folder. In the window, right-click, then select New, then Folder. A new folder will be created, and you'll be prompted to name it.
Haali Media Splitter, LAV Filters, AV Splitter...How do these filters work?
By Moontrash in forum Software PlayingReplies: 3Last Post: 25th Feb 2012, 19:00 -
help with icons on vista home premium
By wingnut2003 in forum ComputerReplies: 11Last Post: 8th Jan 2010, 08:21 -
MSADPCM doesn't work with Vista Home 32 bit
By programm in forum Video ConversionReplies: 1Last Post: 6th Mar 2009, 11:48 -
No capturing programs work on Vista (home premium 32-bit)...
By Rein Engel in forum Capturing and VCRReplies: 8Last Post: 28th Nov 2008, 19:42 -
What is the difference between Vista basic and Vista home premium?
By davidsama in forum ComputerReplies: 18Last Post: 27th Oct 2007, 13:01
