    Jun 2009
    Im sorry to bother you guys again but i am getting an error when i follow the guide to convert file to avi https://forum.videohelp.com/topic360276.html
    when i use xvid4psp it just completely closes the program and wants me to send error report and when i follow the guide using avidemux i get this error....
    i imagine of course its the file ill post what mediainfo tells me...
    General
    Complete name : D:\vids\[AHQ] Gungrave 01-26 [Dual Audio] H264,AAC,5.1\[AHQ] GunGrave - 01 - Destroyer in The Dusk.mkv
    Format : Matroska
    File size : 344 MiB
    Duration : 24mn 22s
    Overall bit rate : 1 975 Kbps
    Movie name : [AHQ] GunGrave - 01 - Destroyer in The Dusk
    Encoded date : UTC 2007-09-03 15:48:15
    Writing application : mkvmerge v2.1.0 ('Another Place To Fall') built on Aug 19 2007 13:40:07
    Writing library : libebml v0.7.7 + libmatroska v0.8.1
    Cover : Yes / Yes / Yes
    Video
    Format : AVC
    Format profile : High@L5.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 16 frames
    Muxing mode : Container profile=Unknown@5.1
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 24mn 20s
    Nominal bit rate : 1 438 Kbps
    Width : 768 pixels
    Height : 432 pixels
    Display aspect ratio : 16/9
    Frame rate : 29.970 fps
    Original frame rate : 29.068 fps
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.145
    Title : Video (H.264/AVC - Resolution: 768x432)
    Writing library : x264 core 56 svn-667C
    Encoding settings : cabac=1 / ref=16 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=7 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=6 / nr=0 / decimate=0 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=1438 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=12 / qpmax=22 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
    Audio #1
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : No
    Codec ID : A_AAC
    Duration : 24mn 22s
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Rear: L R, LFE
    Sampling rate : 48.0 KHz
    Resolution : 16 bits
    Title : Original Japanese audio (5.1 LC-AAC)
    Language : Japanese
    Audio #2
    Format : AAC
    Format profile : LC
    Codec ID : A_AAC
    Duration : 24mn 22s
    Title : English dubbed audio (5.1 LC-AAC)
    Language : English
    Text
    Format : ASS
    Codec ID : S_TEXT/ASS
    Codec ID/Info : Advanced Sub Station Alpha
    Title : English subtitles (Advanced Sub Station)
    Language : Japanese[/url]
  2. Member usta's Avatar
    Jun 2009
    Netherlands
    You should configure the audio channels to "Stereo" in Audio settings. I had similar issue and it helped to limit the number of audio channels to 2.
    Jun 2009
    thanks ill give it a try!
