(Edited Added) NOTE I no longer have the original DVD9 only the DVD9 DVD Directory/VIDEO_TS/files
I ripped a DVD9 to DVD9 with DVDFab 6 to DVD Directory
When I tried to create an Imgae with ImgBurn I got an error message
I want to burn everything to a DVD9 This is animation 1st angle is animation and second angle is story book pictures for some of the scenes and is switchable.
ImgBurn error
Unable to find any cells that could be used for the layer break Now would be a good time to start crying etc. break must be between sectors 1938434 & 2086912 sector 19384 falls within VTS_)! (Title) which starts at 75603
Relative to the start of VTS_01 (Title) the layer break must be between sectors 1862831 & 2011309
Relative sector 186231 falls between PGC 1, Cell 11, which starts at relative sector 1670146
Relative to the start of Cell 11, try splitting betweeb sectors 192685 (376.34 MB) & 341163 (666.33 MB)
Do you want to continue anyway not recommended
I got a similar error message with PgcEdit.
From IfoEdit in part
Menu attributes:
Video: MPEG-2 720x480 (NTSC) (NTSC 525/60) (16:9) (pan-scan)
Audio 1: Not Specified (Dolby AC-3) 2ch 48Kbps DRC
SubPicture 1: Not Specified (2-bit rle )
Title Set (Movie) attributes:
Video: MPEG-2 720x480 (NTSC) (NTSC 525/60) (16:9) (letterboxed)
Audio 1: English (Dolby AC-3) 2ch 48Kbps DRC (ID: 0x80)
Audio 2: Japanese (Dolby AC-3) 2ch 48Kbps DRC (ID: 0x81)
SubPicture 1: English (2-bit rle ) (ID: 0x20,0x21)
with last 2 and layer break info
PGC_1 (program chain): [Title(TTN): 1] [01:30:03.17 / 30 fps] (Programs: 13) (Cells: 27) (uses VOB-IDs: 1,2,1,2,1,2,1,2,1,2,1,2,3,4,3,4,3,4,3,4,3,4,3,4,3, 4,5)
[Ch 12] [Pg 12] [Cell 25] [V/C Id: 3/ 7] (Angle 1): time: 00:05:34.29 / 30 fps [Pos: 01:28:55.19] [Frames: 160069] SP/ILVU/DISC/SA:[yes/yes/ no/yes]
[Cell 26] [V/C Id: 4/ 7] (Angle 2): time: 00:05:34.29 / 30 fps [Pos: 01:28:55.19] [Frames: 160069] SP/ILVU/DISC/SA:[yes/yes/ no/yes]
[Ch 13] [Pg 13] [Cell 27] [V/C Id: 5/ 1] Layer Br.: time: 00:01:07.28 / 30 fps [Pos: 01:30:03.17] [Frames: 162107] SP/ILVU/DISC/SA:[
I have attached the complete ifo file from the main movie VTS_01_0.IFO if you need more info let me know.
Thank you, Joey
NOTE YOU MUST RENAME THIS FILE FROM vts_01_0.txt to vts_01_0.ifo before you can view with IfoEdit
vts_01_0.txt
version 6.0.1.0 Is there anything I can do now if I don't have the original disc anymore?
It plays ok with software players -
I know the earlier versions had a problem with DVD9 to DVD9, but I thought it was fixed. Maybe you just had a bad rip. Has it happened with any other copies?
I would like to get some suggestions of what I can do with the DVD data folder I have to burn a DVD DL+R. I have included a VTS_01_0.txt (rename to VTS_01_0.IFO after downloading) of the main movie as a download file in my first post
In this reply I have included PgcEdit Mapping Info.txt file you can download
I have a lot of free & pay video software tools. Can anyone give me some suggestion of how I could use the DVD9 DVD/VIDEO_TS\files to burn a DVD DL+R disc keeping all the files including both angles?
If you need further info, specs or files please let me know. Thank you, Joey
pgcedit%20mapping%20info.txt
Convert DVD9 layer break to decimal format on Eclipse report?
By sdsumike619 in forum Authoring (DVD)Replies: 4Last Post: 31st Aug 2010, 19:41 -
How to copy DVD9 with subtitle & Burn it in DVD-/+R or DVD9
By prithvi in forum Newbie / General discussionsReplies: 15Last Post: 19th May 2010, 12:37 -
Are all DVD9 double layer?
By jyeh74 in forum Newbie / General discussionsReplies: 1Last Post: 10th Jan 2010, 21:42 -
Setting the layer break on a DVD9 (DVDLab Pro project)
By lorix in forum Authoring (DVD)Replies: 4Last Post: 13th Nov 2008, 12:19 -
How can I find out where a DVD9 layer break is timewise?
By sdsumike619 in forum Authoring (DVD)Replies: 5Last Post: 10th Nov 2008, 17:47
