I would like to know if there is a way to connect 2 computers together, so I can utilize just one capture card? Both systems are well equipped, and I would rather not have to purchase another video capture card, unless there's no other way. Thanks Guy's, GeeJay![]()
are you asking if you can use the same capture card to capture at the same time or just use one capture card and transfer the data to the other computer? If its the later than just network them. If your trying to get computer 2 to use the capture card in computer 1 then the answer is no.
Hi Tommy, the second choice. I want to be able to use the capture card in computer a, and transfer the data to computer b. How would I set up a network connection, as you discribed? G.J.
http://www.amazon.com/
http://www.microsoft.com/
http://www.google.com/
Search: Home Networking
Multiple computers?
By DGenerateKane in forum ComputerReplies: 3Last Post: 25th Apr 2011, 10:28 -
Use Multiple Computers
By ZoNE97 in forum Video ConversionReplies: 8Last Post: 13th Apr 2009, 16:46 -
Your computers. Show them to me.
By Faustus in forum Off topicReplies: 29Last Post: 20th Jul 2008, 12:43 -
computers very slow
By toolady in forum ComputerReplies: 18Last Post: 24th Jun 2008, 09:44 -
5.1 Speakers over two computers
By SIRCOOKS in forum ComputerReplies: 1Last Post: 31st May 2007, 11:43
