Hi
using Adobe Premiere pro CS3 how to buring into DVD ? with following source file formate
FPS -> 25
1090 x 1080i
i'm trying to use Encore but i've done the quality but the video is flexureing
mostly quilty i've saved into M2V file formate ?
which is the best method or software so i can make DVD .
thanks 4 ur reply
Fary
flexureing ?
So you want a DVD-Video that works on dvd players? -
Thanks 4 ur kindly reply
but the 2nd job how can i convert into DVD Player
i've already create DVD but the quality is fine only when it's playing it's play very slow : (
what's the best solutions for this ? -
Hi anybody know's where should be the problem is ? : (
sori wrong post it's should be this one
https://forum.videohelp.com/topic371102.html
Adobe Premiere Pro CS3 & Vegas Pro help
By KS89 in forum EditingReplies: 1Last Post: 8th Sep 2009, 22:52 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 09:00 -
Adobe Premiere pro CS3 to DVD using MP4
By Fary4u in forum Video ConversionReplies: 1Last Post: 13th Jul 2009, 12:13 -
Adobe Premiere Pro CS3 ERROR =/
By ervand in forum EditingReplies: 8Last Post: 11th Nov 2008, 22:28
