Hey guys,
I have been reading through posts and trying to find a solution for a problem that i have but i couldn't so I registered and am posting a new topic hoping for some help please
ok so i have this video that i want to overlay on another video in Avisynth, i did this and everything turned out PERFECT:
a = AviSource("C:\kinky_REXPORTED.avi")
b = AviSource("C:\privatelogo_ani_640x480.avi")
c = b.ConvertToRGB32()
c = c.FadeIn(0)
c = c.FadeOut(10)
Overlay(a, c, mode="blend", mask=showalpha(c))
The video is beeing overlayed and the fadeIn fadeOut works good too, the thing is, how can i choose when the overlay happens, cos the overlay is happening at the beginning of the video, but i would like it to show like at minute 10 or something like that.
So how can i choose when the overlay happens? is there a function that i can add for example to the Overlay(a, c, mode="blend", mask=showalpha(c)) where i can put the time or the frame?
i really need this to work i would appreciate any help.
Results 1 to 13 of 13
Have a look a this thread, uses the Avisynth Trim command.
https://www.videohelp.com/forum/archive/avisynth-jdl-applyrange-amp-fadein-compatibilit...e-t367660.html"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
OOOHHH MAN THANK YOU SOOO MUCH!!!!
i just used the script in that post and changed some stuff and VOILA! it works perfect !
thanks a lot
i have another question, ok so now i can choose when the overlay happens, how about if i wanna put more than one video to overlay over the other in different times during the movie, let's say i wanna use like 20 different clips during a movie of 1h and 30 minutes, do i have to overlay one then export the movie then overlay the other and then export again and so on? or i can put them all in one in the first script?
cos i tried this script but its only showing me the last one, and not all of them by the order i gave them:
a1=AVISource("E:\TITLE02.avi")
a2=AviSource("C:\nametag640x360.avi")
a4=AviSource("C:\nametag_lucy640x360.avi")
a5=AviSource("C:\nametag_trisha640x360.avi")
a3=a2.ConvertToRGB32()
a6=a4.ConvertToRGB32()
a7=a5.ConvertToRGB32()
a1.Trim(0,1376) ++ Overlay(a1.Trim(1377,1553),a3,mask=a3.ShowAlpha(). FadeIO(7)) ++ a1.Trim(1554,0)
a1.Trim(0,2376) ++ Overlay(a1.Trim(2377,2553),a6,mask=a6.ShowAlpha(). FadeIO(7)) ++ a1.Trim(2554,0)
a1.Trim(0,3376) ++ Overlay(a1.Trim(3377,3553),a7,mask=a7.ShowAlpha(). FadeIO(7)) ++ a1.Trim(3554,0)
any idea?
thanks again -
i changed it to this and now its showing me only the first!!! i really dunno how to do that
a1=AVISource("E:\fire.avi")
b1=a1.Trim(0,1376) ++ Overlay(a1.Trim(1377,1553),a3,mask=a3.ShowAlpha(). FadeIO(7)) ++ a1.Trim(1554,0)
b2=a1.Trim(0,2376) ++ Overlay(a1.Trim(2377,2553),a6,mask=a6.ShowAlpha(). FadeIO(7)) ++ a1.Trim(2554,0)
b3=a1.Trim(0,3376) ++ Overlay(a1.Trim(3377,3553),a7,mask=a7.ShowAlpha(). FadeIO(7)) ++ a1.Trim(3554,0)
e=b1++b2++b3
e
soooo confused
a1 = a1.Trim(0,1376) ++ Overlay(a1.Trim(1377,1553),a3,mask=a3.ShowAlpha(). FadeIO(7)) ++ a1.Trim(1554,0)
a1 = a1.Trim(0,2376) ++ Overlay(a1.Trim(2377,2553),a6,mask=a6.ShowAlpha(). FadeIO(7)) ++ a1.Trim(2554,0)
a1 = a1.Trim(0,3376) ++ Overlay(a1.Trim(3377,3553),a7,mask=a7.ShowAlpha(). FadeIO(7)) ++ a1.Trim(3554,0)
return a1 -
OHHH thanks a lot man, i tried this and it worked too
a1=AVISource("E:\DVDZzz\HARD Private\new\Nueva carpeta\Nueva carpeta\XXX40PAL_SCN\lickmyfire.avi")
c1=AVISource("C:\Users\marwan.labban\Desktop\mobil eTV Tags\nametag640x360.avi")
a2=AviSource("C:\Users\marwan.labban\Desktop\mobil eTV Tags\privatelogo_ani_640x360.avi")
a4=AviSource("C:\Users\marwan.labban\Desktop\mobil eTV Tags\nametag_lucybelle640x360.avi")
a5=AviSource("C:\Users\marwan.labban\Desktop\mobil eTV Tags\nametag_trisha640x360.avi")
c2=c1.ConvertToRGB32()
b1=a1.Trim(0,1) ++ Overlay(a1.Trim(0,200),a3,mask=a3.ShowAlpha().Fade IO(7)) ++ a1.Trim(201,0)
b2=b1.Trim(0,1600) ++ Overlay(b1.Trim(1601,2000),a6,mask=a6.ShowAlpha(). FadeIO(7)) ++ b1.Trim(2001,0)
b3=b2.Trim(0,1000) ++ Overlay(b2.Trim(1001,1300),a7,mask=a7.ShowAlpha(). FadeIO(7)) ++ b2.Trim(1301,0)
b4=b3.Trim(0,376) ++ Overlay(b3.Trim(377,553),c2,mask=c2.ShowAlpha().Fa deIO(7)) ++ b3.Trim(554,0)
b4
thanks for the help -
De nada, hombre.Originally Posted by WAKA
I think you've got the idea now, but you could make it simpler if you want, and do the whole thing in one statement.
a1.Trim(0,1) ++ Overlay(a1.Trim(0,200),a3,mask=a3.ShowAlpha().Fade IO(7)) ++ a1.Trim(201,376) \
++ Overlay(a1.Trim(377,553),c2,mask=c2.ShowAlpha().Fa deIO(7)) ++ a1.Trim(554,1000) \
++ Overlay(a1.Trim(1001,1300),a7,mask=a7.ShowAlpha(). FadeIO(7)) ++ a1.Trim(1301,1600) \
++ Overlay(a1.Trim(1601,2000),a6,mask=a6.ShowAlpha(). FadeIO(7)) ++ a1.Trim(2001,0)
Although, I agree your method makes it easier to add and remove individual overlays.
Incidentally, is there a reason for putting a1.Trim(0, 1) at the start? -
Hey Gavino, yes it is much simpler and easier, am just new to editing video with a script so am learning
but i will definitely use your script
The a1.Trim(0, 1) at the start is cos i have a small intro video at the beginning, but i want it to be overlayed, although i would like it to be from the start (frame 0) but i cant cos i tried a1.Trim(0, 0) but it doesn't show so i left it at (0,1) and then i used the virtualDub to remove the first frame.
I really like avisynth, it will save me a lot of time
Thanks again for the help
In that case, just leave out the a1.Trim(0, 1), and start withOriginally Posted by WAKA
Overlay(a1.Trim(0,200),a3,mask=a3.ShowAlpha().Fade IO(7)) ++ etc -
thanks man, well i fixed all the script and named everythin in a nice way but now it isnt showing anythin, i dont think i have errors in the script
m1 = AVISource("E:\DVDZzz\HARD Private\new\Nueva carpeta\Nueva carpeta\XXX40PAL_SCN\lickmyfire.avi")
m2 = AviSource("C:\Users\marwan.labban\Desktop\mobileTV Tags\privatelogo_ani_640x360.avi")
n1 = AviSource("C:\Users\marwan.labban\Desktop\mobileTV Tags\nametag_eufratbianca640x360.avi")
n2 = AviSource("C:\Users\marwan.labban\Desktop\mobileTV Tags\nametag_kathylola640x360.avi")
n3 = AviSource("C:\Users\marwan.labban\Desktop\mobileTV Tags\nametag_michellezoe640x360.avi")
n4 = AviSource("C:\Users\marwan.labban\Desktop\mobileTV Tags\nametag_cindyrenata640x360.avi")
n5 = AviSource("C:\Users\marwan.labban\Desktop\mobileTV Tags\nametag_anita_natali_defrancesca640x360.avi")
o1 = m2.ConvertToRGB32()
o2 = n1.ConvertToRGB32()
o3 = n2.ConvertToRGB32()
o4 = n3.ConvertToRGB32()
o5 = n4.ConvertToRGB32()
o6 = n5.ConvertToRGB32()
Overlay(m1.Trim(0,100),o1,mask=o1.ShowAlpha().Fade IO(7)) ++ m1.Trim(101,0) \
++ Overlay(m1.Trim(200,300),o2,mask=o2.ShowAlpha().Fa deIO(7)) ++ m1.Trim(301,0) \
++ Overlay(m1.Trim(401,500),o3,mask=o3.ShowAlpha().Fa deIO(7)) ++ m1.Trim(501,0) \
++ Overlay(m1.Trim(601,700),o4,mask=o4.ShowAlpha().Fa deIO(7)) ++ m1.Trim(701,0) \
++ Overlay(m1.Trim(801,900),o5,mask=o5.ShowAlpha().Fa deIO(7)) ++ m1.Trim(901,0) \
++ Overlay(m1.Trim(1001,1100),o6,mask=o6.ShowAlpha(). FadeIO(7)) ++ m1.Trim(1101,0)
return m1
if I delete the last line, then it will show me the last one again and if i keep it i dont see anythin!! weird
Sorry! if i delete the last line (return m1) then it will show me the the first overlay (which is the o1) only, and if i have the last line then none of them apear
thanks again for the help -
Those zeroes should be 199, 400, 600, 800 and 1000.Originally Posted by WAKA
Zero as the 2nd param in Trim means 'include up to the end of the clip'.
So only the last one (1101, 0) is correct. For the others, you need to stop at the frame before the next overlay.
And, yes, delete the last line since you want to return the result of splicing all the overlays. -
A-MAZING!!!!
Everything works perfectly! Amazing software and thanks to you my work is gonna be much easier!
Thanks a lot for the help, I really apreciate it, YOU ROCK!!!!
AVISynth Overlay Image Help
By smike in forum EditingReplies: 11Last Post: 17th Sep 2012, 12:04 -
AviSynth Overlay and Trim Help
By NMeade in forum Newbie / General discussionsReplies: 20Last Post: 1st Apr 2012, 08:53 -
Using AVISynth to overlay PNG subtitles?
By csdesigns in forum SubtitleReplies: 8Last Post: 3rd Feb 2012, 12:36 -
avisynth - overlay fadein from transparent
By doma79 in forum EditingReplies: 12Last Post: 6th Dec 2011, 12:38 -
AviSynth Audio Overlay
By legocrazy1 in forum EditingReplies: 7Last Post: 14th Jul 2010, 11:01
