"Oh look, honey....nurds!"![]()
Results 31 to 60 of 81
zzzzzzzzzzzz................Originally Posted by zoobie
Funny thing about this kid that likes calling me a "nurd", Look @ this assclown's "hand coded websites" and you will see a hereto never before seen level of nurd, I mean this guy is really "pushing the nurd envelope"
http://buskercentral.com/
dudes a freakin' nurd legend
rotflmao
ocgw
peacei7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
https://forum.videohelp.com/topic368691.html -
Lol....K..Back to my problem...I'm backing up to PC number 1 to protect from damage that my little one has done to disks and number 2 the ease of selecting from remote control...My PS3 I stick with games and watching Blu-Ray that I cant run from my Media Center. I dont understand how to stream the M2ts file from my PC to my Ps3. I dont have problems with other video just Blu-Ray. Nor can I use an ISO with my Ps3. Anyhelp would be great.
Next example. I tried Watchmen. The intros play without a problem but as soon as the "main movie" is supposed to start the screen freezes. Well not freezes exactly. Just black screen. I click stop. The main Powerdvd logo screen appears. I ripped to file mode to see what would happen if I just played the m2ts file and it has no single movie file. Its split into several files and language is foreign for the multiple movie files.
I did Coraline the other day. Not a problem except I have to deal with a scrambled image until the main movie starts. Then its flawless. Dark Night Iso will not play at all and the M2ts file is skippy.
PC specs
Media Center 05
AMD Athlon 64x2 Dual Core 4200+2.19Ghz
2.5 GB Ram
ATI Radeon HD 4550 512MB
I have very minimal software running. Primarily software for Media Center to operate. Ive got Directx9c installed. Cant install 10 cause I dont have vista.
I can upgrade my Ram another half gig to make a total of 3 gig instead of 2.5. If you think that will help.
I have my video running 720p through HDMI.
I've tried several different versions of Powerdvd 7.3-whatever...At least I have the key that came bundled with my player....
I've installed more codec packages than I have ever seen in my life. (Prolly dont need most of them)
Splitting the M2ts file then remuxing it sounds like a pain but I know nothing about that process so I mite have to look into that as long as I lose NO quality. I just like the idea of single ISO that with 1 click was done.
I still dont understand when the decrypting process happens. Is it when I rip to ISO or is it when the ISO is playing? Where is the selection for completely removing the encryption?
I read so much stuff and it sounds like everyone has it so simple. Am I makeing it harder than it is? Thanks for any help..... -
The simple way to do it is................Originally Posted by alucard2050
1.Use TsMuxeR w/ Slysoft AnyDVD HD running in the background to strip out copy protection, extra subtitles and unneeded sound tracks, and to also join the many individual .m2ts files of a "seamless branching disc"
2. Make iso w/ imgburn, put each iso files in a folder named after the movie so you can use it w/ the MyMovies front end later
play iso w/ PDVD
these are the 2 programs that you must learn to use, ppl here will help you get past any sticking points
3. After you master 1. and 2. we will help you set up MyMovies in media Center
btw AnyDVD rips out the protection when it rips by default unless you tell it not to
TsMuxeR does the demuxing (splitting) and the remuxing (rejoining) for you
ocgw
Just tried Haali Media splitter for the M2ts file from Dark Night...Audio was of by about 3 seconds. Tried a few different settings but same result. Also the audio and video was VERY choppy. The choppy I was getting from playing the straight m2ts was more of a skipping like it was skipping frames. Doing this was choppy and freezing.
You are not going about it the right way m8Originally Posted by alucard2050
It is choppy because when you play the .m2ts rather than iso you do not get gfx hardware acceleration, and your using a mid level dual core cpu from 3 years ago, it is not quite up to the task
Now you have a great gfx card, it will handle HD video w/o much help needed from the cpu
stick to making iso work my friend
ocgw
hmmm...i was ripping straight 2 iso with anydvdhd...so you think if I demux then remux as you described that mite help? what about the sound delay that I had with my test I ran? I just used haali splitter...are there setting I have 2 set when I demux and remux? does this process still keep the 1080p as well as 7.1 sound? thanx
TsMuxeR is a evolved tool, you won't have any sync issues, it remuxes and demuxes in 1 step, and you can pick what ever sound tracks or subtitles you want, and the original movie is untouched 1080pOriginally Posted by alucard2050
2-step process should take less than a hour on your PC
ocgw
sweet! I will try this process when I get home later...i truly only want the movie. I've got no need for a menu or chapter selection. except for fast forwarding....and subtitles and other languages I usually leave off my dvd rips so bluray can do without...sweet! I didn't know I could take that stuff out. I thought it was only straight 1 to 1 copy.......
alucard2050, how are you streaming from PC to PS3?
What software are you using and are the files streamed using hardwire or wifi?Regards,
Rob -
saves a heck of a lot of space on the HDD tooOriginally Posted by alucard2050
ocgw
I'm useing ps3 media server....wifi connection...i can do some wma files and mpeg files and dvds are the vob files. no bluray files or isos will work. unless I'm missing sumthing there on the ps3 front....
I think the wifi may be an issue - you are asking it to stream a lot of data (20Gb+) in real-time.
Strip the non-essential crap out using TSMuxer to get your m2ts file and see if you can copy it to PS3 over wifi using your media server (disrect the PS3 to the file on the server and press the green triangle and chose copy).
If it takes longer to copy the file than it's duration, your wifi is a bottleneck.Regards,
Rob -
PS3 and wi-fi isn't my "thing", but can't you run a ethernet cable to PS3?
ocgw
OK..I'm at the point of tsmuxer...im lost. in the input is where i place the m2ts file correct. I'm currently doing Dark Night cause its just 1 file. I'm checking the video and the trueHD boxes for video and audio..is my output supposed to be m2ts or another format?Do I need to mess with anything under the other tabs like General/Blu-Ray/split and Cut/ Ect.......? Then on Imgburn do I need to select certain options or use default? And when I make the ISO file am I just useing the newly created m2ts file or do I need other files? Thanks..........
BTW-I am unsure about my ps3..If I can get this to work in my PC with Media Center like my dvd collection does I will happy..My second option might be to get an external drive hooked up to my Ps3 and if possible run the Blu-Ray backups from it. Problem with that is if my little girl wants to watch something its going to be on the main TV instead of playing in her room......... -
Nah, navigate to the Streams folder and choose the biggest m2ts file, play with MPCHC to make certain it's the main movie. Now go to the Playlists folder and select the associated *.mpls file. Example: say the main movie is 00002.m2ts, choose the 00002.mpls file. That way you're certain to keep the chapter info if output is BD or AVCHD. Click the Blu-Ray tab and you'll see the chapters are set at "Custom" and the timings will be in the list. The 00002.m2ts will load, along with audio tracks and all PGS (Presentation Graphics Streams) files (subs). Deselect what you don't want and "Start Muxing".
Good luck.
[EDIT] Dunno anything about your PS3 or Wii, so dunno what your output should be.
Pull! Bang! Darn! -
90-95% of the time using the largest .m2ts file works, set the output to blu ray, if the rip fails, or if the movie is broken up into several small .m2ts files I suggest using the mpls fileOriginally Posted by alucard2050
I suggest using 1 of these 3 to find the correct mpls file
BD Info
BD Edit
eac3to
of the three actually eac3to is my fav
ocgw
Ummmmm..Problem. I select the main movie m2ts file...it breaks out into the different audio files and subs files but there is NO mpls file for the audio...all the files are 00007.m2ts but the codecs are different. so I selct the true hd file for audio as well as the main video file.......now its talking about changing to udf and file size too large. I did those popups.....should my output be checked TSMUxing/ M2ts muxing/ Blu-Ray/ Ect..Ect......? Also everything I had selected for this test I'm currently doing gave me nothing as far as keeping the original chapters.....
Set output to blu rayOriginally Posted by alucard2050
TsMuxeR by default makes a chapter every 5 minutes
ocgw
Now i've already ripped the actual disk and am loading the m2ts file from my hard drive correct? In Dark Night I have found the main movie m2ts file...Its only 1 file...But I set my output to m2ts not blu-ray................wait a minute..when I add files to tsmuxer. do I need other files from the blu-ray other than the main movie file or just that 1 single file? (In this case Dark Night movie is just 1 m2ts file but are chapters in another file somewhere from the rip?)....I selected the main movie file and the file for true HD as the audio and removed the other files which I assume are the spanish and french and subs...Let me try the blu-ray output mode now......
the 1 .m2ts file has everything you need in itOriginally Posted by alucard2050
going to bed now see ya' tomorrow
ocgw
Success!!!Dark Night is now a success...The new ISO plays flawlessly..Now to move forward to Watchmen that is split into multiple m2ts files...Thank you thank you thank you.....lol
TsMuxeR is sweet ain't it, and it is made in Russia lolOriginally Posted by alucard2050
ocgw
Seems like when I select an m2ts file I dont get what i'm looking for. But when I select the correct mpls file it gives me exactly what I am looking for. I did Watchmen this way but I selected the mpls file that contained the movie but had some commentary cuts during diffferent scenes so I'm trying the other big mpls file. Is there a way to preview what you are about to do or in the process of doing with tsmuxer or do you have to wait for the finished product?
If there is director's comments video in a single .m2ts 98% it is because there is a 2nd video stream (usually @ a lower res)Originally Posted by alucard2050
only pick 1 video, and 1 audio and 98% of the time you will be ok w/ the right .m2ts
sometimes you have 2 seperate main movie .m2ts files and the slightly shorter 1 is the the 1 w/o director's comment
the top mpls picked by eac3to is always the right main movie in my experience
Although you can get away w/ just picking the big .m2ts file 95% of the time mpls is always the preffered method w/ Tsmuxer, sometimes they will fool ya' w/ 2 big .m2ts files and it is not 1 w/ directors comments and 1 w/o, it will be 2 halves of the movie as a "layer break"
every movie is different
ocgw
Success with Watchmen
I'm heading to redo my other ISOs so I can strip out the fancy uneeded stuff..Its only about 4 movies...lol......My next step is to get this like you said to run from Mymovies in 2005 media center.....I used it for a small amount of my DVD collection but thought it was easier to have my vids in folders then click on the folders containing VIDEOTS folder and the DVD would start.....If there's a way to do this with blu-ray ISOs that I'm now understanding a little more that would be great. At the moment I have to mount each ISO each time and reopen Powerdvd. I have Powerdvd app installed in media center but all it does is minimize media center and open Powerdvd......Can this be done with the blu-ray ISOs to play within Media Center 05? It would be easier if I was watching a movie and if it got boring being able to simply select another folder from with the program rather than have to screw around with a mouse. Mounting and unmounting each time...Thanks..Its beeen truly a help so far..................
I just redid caroline which had the scrambled video at the intro screen but the main movie played fine. I was going to eliminate the junk stuff and keep the main movie just like I have now done with Watchmen and Dark Night. On completion the movie was scrambled. I swear its like I see the images of the movie but the are loaded with multicolor blocks. this has to be some kind of codec issue. Or maybe some kind of issue switching from 1 format to another. Its weird.....
OK, you're doing fine, now just drop the iso files in a folder the same name as the movie, this is how Media Center/MyMovies will auto recognize the movie and it will give it somewhere to put the coverart and stuffOriginally Posted by alucard2050
If you have.........
1. VCD set as the default program to open iso files
2. PDVD as the default program to open Blu Rays
3. PDVD's default disc drive is your VCD drive letter
4. PDVD autoresume setting is "always play from the beginning"
5. PDVD set to "run @ full screen"
6. PDVD set to default player of blu ray in Auto play properties
then all you have to do is click on the iso file 1 time and it will open up to full screen and play w/ 1 click
when you click on a iso file, or elect it in Media Center VCD automatically unmounts the last movie, no need for manual unmounting
When you have MyMovies installed when you click on your movie it will close MC, open PDVD, and play the movie from the beginning @ full screen
Just like magic
ps. a shortcut to a iso icon can be substituted for a bitmap of the coverart
ocgw
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15 -
M2TS, AVCHD, BLU RAY Playback Problem on Sony Blu Ray Players
By messi magician in forum Authoring (Blu-ray)Replies: 11Last Post: 15th Jan 2012, 19:25 -
Wanna convert Blu Ray Movie to Play on Laptop/PC without a Blu Ray PLayer !
By augustya in forum Blu-ray RippingReplies: 5Last Post: 13th Aug 2011, 04:35 -
Introducing Ray in Blu Rendr - Digital Media Receiver Blu-ray Disc
By rayinblu in forum Newbie / General discussionsReplies: 6Last Post: 15th Apr 2010, 10:37 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 17:05
