I need to convert a .dts file from 25fps to 23.976. I tried using besweet but keep getting error messages.
It is a 7 ch .dts file, is that a problem?
Im trying to convert a .dts file from 25fps > 23.976 using besweet.
Settings:
Besweet
- Use dts decoder azidts
- Pal 25 > 23.976
- Output PCM Wav
AC3/OGG/PCM
- Wav 16bit 6 mono files
But I get a DshowERR, FAILED IN CREATEFILTER Message and the sweetlog file is empty...
Get the same results for .dts to .ac3 ERROR...
Results 1 to 10 of 10
ranosb, please do not double post. I've deleted the other topics. If you want to move a topic to another forum, PM a Mod. Continued multiple posts will get you a warning card.
Moderator redwudz -
Ok trying ea3to for ac3 and dts.
Creating an .ac3 file always produces a msg "clipping detected, a 2nd pass will be necessary"
And, "Sonic decoders don't seem to work, will use Libav"
Why does this not produce a single .dts file, instead of 6 wav files?
"eac3to.exe" "track_2.dts" "FIX.dts" -down6 -slowdown ( Its a 7ch .dts file) -
Take a look at the OP of this thread
http://forum.doom9.org/showthread.php?t=125966
Unless you have a dts encoder,
"eac3to source.dts target.ac3 -slowdown" is the right command for your need.
You don't need -down6 option 'cause it is automatically taken care of and you can safely ignore other error messages. -
I have Soft Encode and SurCode DVD PROOriginally Posted by yonta
I dropped the .dts file in Soft Encode and the program just crashes...( I believe it only takes wav files)
The SurCode DVD PRO 1.0.23 produces a msg "parallel port lock required" when I try to open a file with it...
This link to surcode;
Which download do I need, they have so many?
http://www.minnetonkaaudio.com/products/surcode.html -
Thats what happens when you use pirated software 8)
******* released this on 02/22/01 as retail, but was useless since the
dongle protecion was not removed : If you try to Encode with it you will
get a "Parallel port" error. -
Well thanks for that note...I will ask for a refund from where I got it...
Thanks for the tip.Originally Posted by yonta
Eac3to (.dts > .ac3) eac3to source.dts target.ac3 -slowdown
This works! Iv'e had problems in the past using eac3to, but I guess it depends on the source
I dont know why it always has to do a second pass (Clipping detected).?
Now I will try
Eac3to (.dts > .dts) eac3to source.dts target.dts -slowdown (which will produce 6 wav files)
That I will try to load into SurCode DVD PRO 1.0.21 & soft encode to see what kind of results I get...
THANKS GENTS
How Can I Convert 25FPS 720P To 23.976?
By wulf109 in forum Blu-ray RippingReplies: 4Last Post: 23rd Nov 2011, 21:47 -
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 21:24 -
25fps BD with MBAFF to 23.976
By Anonymous344 in forum Video ConversionReplies: 11Last Post: 5th Jun 2011, 18:21 -
How to stretch a DTS audio file from 23.976 to 25.000 fps?
By lorix in forum AudioReplies: 3Last Post: 10th Nov 2008, 13:55
