Instead of all this re-encoding stuff just to get your VCD's onto DVDR... Is it not possible to ( With NERO ) Select the 'DVD ROM' complilation.. and duplicate all the relevant files and folders that make up a standard VCD ( i.e CDI / MPEGAV etc. etc. ) and drag and drop them into your DVD ROM compilation and add your Mpeg VCD files ?
Its just that... ( Please correct me If I'm wrong ) I am under the impression that a blank DVDR is just a means to store a larger amount of Data.....
Its just an idea........![]()
Paul. ( UK )
VCDs are not CD-ROMs and the physical layout of the thing is very important. For example, a hardware VCD player doesn't read (it doesn't need to) the actual filesystem on a VCD as you would on the PC. It gets all the video, still images, menus, etc., by directly reading predetermined physical sectors on the VCD.
If you just do a file copy of a VCD, it will not work, not even on CD-R/W media. Thus, it is extremely unlikely to work on a DVD-R/W disc.
Regards.Michael Tam
w: Morsels of Evidence
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
Magnavox NB500MG9 (walmart) BD player..Nero vision..BD on DVDR working?
By markm75 in forum Authoring (Blu-ray)Replies: 8Last Post: 1st Dec 2008, 02:11 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 17:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19
