I have recently bought a Pioneer DCS-575 Home Theater. According to specs., it should be able to play back audio, encoded in MPEG4-AAC, iTunes flavour, and recognize aac audio, if the *.m4a fileextension is used.
I have tried to convert an audio sample from PCM *.wav to AAC *.m4a, with Apple iTunes version 8.2.0.23, and it runs smoothly. Have tried 48KHz source downsampled to 44.1KHz an coded as 256Kbps VBR, an 48KHz coded as 128Kbps CBR. No problems.
Normally I would use MeGui to encode video and audio. In MeGui one can choose from three flavours of AAC, that is Winamp-AAC, FAAC-AAC, or Nero-AAC. Nothing of this wil play in the Pioneer DCS-575
When analyzing the files with Gspot, Nero-AAC seems to come closest to iTunes. See copy/paste below.
My question is then, is there a tool, which can open an *.m4a file, and modify the container- and userdata/metadata information?
Quotes from Gspot, note the small differences:
QuickTime - iTunes:
Container:
M4A : Apple iTunes AAC-LC (.M4A) Audio
- mp42: MP4 v2 [ISO 14496-14]
- isom: MP4 Base Media v1 [IS0 14496-12:2003]
Created: 2009 Jul 13 13:00:36
Modified: 2009 Jul 13 13:00:47
User/Meta data:
İnam:testlyd
İtoo:iTunes 8.2.0.23, QuickTime 7.6.2
Nero:
Container:
- M4A : Apple iTunes AAC-LC (.M4A) Audio
- ndia: <unknown>
Created: 2009 Jul 13 11:15:12
Modified: 2009 Jul 13 11:15:19
User/Meta data:
İtoo:Nero AAC codec / 1.3.3.0
	Okay. So I have done as suggested.
 Gspot now says:
 Container:
 Created: 2009 Jul 13 20:08:43
 Modified: 2009 Jul 13 20:08:43
 User/Meta data:
 ( empty - nothing )
 Hmm. Looks more like the original iTunes, the container starting with "M4A : Apple iTunes AAC-LC (.M4A) Audio ". What worries me is two missing atoms "İnam:" and "İtoo".
 If the User/Metada "İtoo:Nero" instead of "İtoo:iTunes ... " is what the Pioneer trips over, then ...
 I will keep you posted, when I have tried to run it on the player. (Won't be able to do so until Friday").
	A big thanks to b66pak!
 The suggested procedure worked like a charm. The Pioneer device plays the converted AAC files.
 And even better: I got confirmed, that the Pioneer DCS-575 not only plays conventional 2-channel AAC audio, but also 6-channel AAC audio. Quite usefull when converting movies with large DTS audio-files to MP4.
  .aac to .m4a.. possible?By romi7519 in forum AudioReplies: 35Last Post: 14th Dec 2018, 06:45
  Problems about aac audio in TS filesBy ihmcjacky in forum Video ConversionReplies: 4Last Post: 30th Nov 2010, 02:24
  Normalizing AAC filesBy k. in forum AudioReplies: 1Last Post: 12th May 2010, 19:56
  Convert AAC 6ch to AAC 2ch w/ Dolby Pro Logic II Surround infoBy SiegeX in forum AudioReplies: 5Last Post: 28th Dec 2009, 17:58
  M4a to AAC ConverterBy Dave1024 in forum AudioReplies: 6Last Post: 27th Jul 2009, 22:44
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
