I know this question has been asked a million times.
I followed the instructions in this guide but it only shows me how to add the subtitles and doesn't show how to select different subtitle track. There are 3 different languages in my .sub file English, Chinese and Japanese. I want to select Japanese subs but in the preview it only shows default English subs.
How do I select a different subtitle track according to that guide?
The further away I get from the things that I care about...
the less I care about how much further away I get... -
Use VobSubStrip to first get only the language you want and then follow the guide with the Japanese IDX/SUB file:
http://www.free-codecs.com/download/VobSubStrip.htm
Another way is to edit the IDX to make the Japanese one the default:
If the Japanese language is the third language of the three, change langidx to 2.# Language index in use
langidx: 0 -
Thanks! Will give it a try.
How to add idx/sub hard subtitles to mkv
By 2ndlife in forum SubtitleReplies: 5Last Post: 29th Dec 2011, 21:22 -
Add/remove sub idx to/from vob
By ystiang in forum SubtitleReplies: 6Last Post: 8th Jun 2010, 22:50 -
use AviSynth script to add graphic idx/sub subs in DVD Flick?
By MilesAhead in forum SubtitleReplies: 7Last Post: 17th Dec 2009, 12:24 -
Checked stickies, cant add the idx/sub files to a video
By Kaminoshi in forum SubtitleReplies: 8Last Post: 9th Jul 2008, 12:57 -
How do you add switchable .idx / .sub to dual audio .AVI (XviD)?
By NextJinGamer in forum SubtitleReplies: 4Last Post: 1st Jul 2008, 16:42
