Hello, I found some old VHS (10-15 year old) and started to capture with my Pinnacle 710 USB.
The problem is the quality of the VHS, the images "shakes" a lot (not because of the recoring but because of the old VHS).
Is there a software to improve this?
Thank you!
well, you could try stacking the images on top of each other with the deshaker filter for virtualdub
or buy a better player with a built-in TBC -
THanks, is there a lower budget way? like just software without buying any extra hardware?
Thanks -
Your problem might be your VCR. Many of them made since 2005 are very poor at playing recordings they did not make, especially EP recordings.
For a cheap hardware solution, try borrowing a 10 year old unit. Quasar and Sharp are not hard to find and both tend to track and stabalize old recordings well. 20 to 25 bucks is what I have paid for them at Goodwill stores in central Illinois....3 days to test and return for full refund. -
Yes, sorry. I'm not sure if he edited the post or I was reading somewhere else but I saw somthing about buying some special hardware.Originally Posted by fitch.j
Thanks! will try virtualdub -
I downloaded deshaker and copied it to the plugins folder. but when I try to add the filter (I have to click on load because it does not appear) it says it's not a valid win32 application. Is there something missing?
I run vista 64 bits and downloaded virtualdub 1.9.3 64bits
thanks!
Best capturing method from VHS to digital format with highest quality?
By jbloggs in forum Newbie / General discussionsReplies: 10Last Post: 14th Nov 2015, 04:36 -
Capturing from old VHS and improving quality of cartoon
By Abbadon in forum RestorationReplies: 35Last Post: 24th Nov 2011, 09:22 -
restore 27 year old VHS. please help!!!!
By jatink129 in forum RestorationReplies: 24Last Post: 4th Nov 2011, 06:46 -
How go i get the same vhs quality when capturing and converting to dvd?
By Whuntmore in forum MacReplies: 43Last Post: 28th Feb 2010, 06:30 -
VHS to DVD - is there any way I can improve quality of conversion?
By rairjordan in forum Capturing and VCRReplies: 21Last Post: 13th Feb 2009, 13:32
