I have some avi format movies that I would like to convert to dvd so I can watch them on my tv. Usually I have good luck using DivxtoDvd to convert them and they play just fine. However lately I have had some of the movies that when they get converted to dvd the sound becomes offtrack. It is like watching a old b rated Japanese movie where the lips move and then the sound comes out.
Is there a better program that I should be using? I liked Divxtodvd because it supported putting several shows on one dvd.
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 14:44 -
I need some advice, problems with the sound becoming offtrack
By maverickboy2007 in forum Newbie / General discussionsReplies: 7Last Post: 16th Nov 2008, 05:04 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
