Why is my mini DV video captured and burn on DVD ended up in lower quality?
Captured Sony's mini DV (sony digital trv 27 handycam) video to my PC using Sonic DigitalMedia Plus v7 software. Video Codecs version is Divx 5.2.1. However, the video captured and burned is in much lower quality (resolution wise- little squares on screen) than the original mini DV as seen by directly connecting to TV. I Used USB cable plus a composite cable (for sound) to connect the viewcam and PC.
Before I had captured video using video All-in-Wonder captured card, and the quality was much better. I gave away the old system.
If I want to capture video directly from the mini dv video camara, can I do anything to improve the quality? Thanks!![]()
miniDV has to be captured using firewire from the cam to the computer to get the full quality DVavi off the tape and onto the hard drive.
Your USB capture off a trv27 would be 352x240.
An IEEE-1394 (ILink/Firewire) capture would be at 720x480i.
Transfer with WinDV, then encode.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thank you edDV and miniDV for your quick answers. I really appreciated it.
I always suspected the culprit is USB. I had googled the difference between USB and firefire but couldn't find an answer. Should have come here earlier. I will try to use ilink and will report the results. Thanks.
Hi8 -> DV -> Final Cut Pro = Low, low audio levels in captured video
By xmiller in forum Capturing and VCRReplies: 12Last Post: 14th Dec 2010, 16:59 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 13:38 -
Captured HD Video - want to put on DVD in HD quality
By Coroner in forum Newbie / General discussionsReplies: 6Last Post: 7th Dec 2008, 15:32 -
Low quality youtube video WHY?
By yunakokimama in forum Video Streaming DownloadingReplies: 0Last Post: 29th Oct 2008, 15:58 -
low quality S-video connexion
By szermatten in forum Newbie / General discussionsReplies: 17Last Post: 10th Dec 2007, 13:50
