Hi!
I hope someone can help me with this, cause i am stuck!
I am going to add ahrdsubs to a video (vob) using virtualdubmod, but the video is blurry. Maybe blurry isn't the right word... When there is movement in the video the edges aren't sharp like they should be. It is liek the image is good, then blurs, then good, then blurs etc.
I used to have a filter that removed that kind of distortion, (had to buy a new computer - long story, i lost everything) but i can't seem to find it again.
Sounds like someone used a temporal denoiser on the video. There's really no way to undo that. Post a sample and we'll see.
I might have used some sort of denoiser, but i can't remember it being called that.
Here is a screenshot:
Can you see the lines blurred/distoreted? I'd like to make those go away, hopefully it is possible! -
THANK YOU!!
That was what i needed to do. I found a deinterlace filter, which was what i used before.
Thank you so much for your help
How to remove video blur?
By Djard in forum Newbie / General discussionsReplies: 10Last Post: 26th Aug 2010, 23:38 -
Blur
By jfreak53 in forum EditingReplies: 3Last Post: 24th Apr 2010, 15:22 -
youtube video is very blur!
By yunakokimama in forum Video ConversionReplies: 1Last Post: 14th Oct 2008, 15:16 -
blur stuff out?
By zookeeper525 in forum EditingReplies: 8Last Post: 3rd Feb 2008, 07:52 -
motion blur on tv
By ineedhelp007 in forum Newbie / General discussionsReplies: 3Last Post: 18th Dec 2007, 10:49
