All the tools I look at only allow me to have AAC encoded audio when creating an MPEG-4 TS. Is there a tool that will allow me to use Mpeg-1 Layer I, II or III Audio? So far I've tried with Basic, Improved and H.264 setting, but all force me to do AAC audio. I am going to attempt to create the files separately as an MP4 video and MP3 Audio put together in QT Pro to see if that will play.
Also I have been asked if I can send an H.263 version, but the only way I can do that is as a .mov Quicktime file, i am waiting to hear back if that would be acceptable. Any ideas?
Looks Like the AVS4You Converter is the one for me, as long as the quality is good. Downloading and testing now.
Actually I'll need to do both convert and get a muxed file. I'll look into to your link now, after looking into AVS4You I can already see it is not so great. Thanks.
XviD4PSP will create mp4 (with x264 or XviD video) and mp3 audio.Originally Posted by cthompson
Complete name : D:\sample.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 6.51 MiB
Duration : 1mn 0s
Overall bit rate : 908 Kbps
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : avc1
Duration : 1mn 0s
Bit rate mode : Variable
Bit rate : 720 Kbps
Maximum bit rate : 1 180 Kbps
Width : 640 pixels
Height : 272 pixels
Display aspect ratio : 2.35
Frame rate mode : Constant
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.173
Stream size : 5.15 MiB (79%)
Writing library : x264 core 65 r999kMod cc51047
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 6B
Duration : 1mn 0s
Bit rate : 185 Kbps
Minimum bit rate : 192 Kbps
Maximum bit rate : 203 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 1.32 MiB (20%)
Writing library : LAME3.97
Encoding settings : ABR
Why is my audio saying mono after its muxed?
By killerteengohan in forum AudioReplies: 6Last Post: 7th Feb 2012, 10:23 -
Best way by using MPEG STREAMCLIP to convert MPEG2 Muxed at 720 x 404 ?
By DTRON in forum Video ConversionReplies: 1Last Post: 21st May 2010, 16:22 -
Probable Codec problem. No audio on MPEG2 muxed files
By Kevlin in forum MacReplies: 14Last Post: 17th Apr 2010, 03:05 -
Quicktime parse error converting mpeg-1 muxed to DV or mpeg 4
By jglass in forum Newbie / General discussionsReplies: 0Last Post: 15th Jun 2008, 20:51 -
No sound when converting muxed mpeg-1 file to AVI DivX!
By mute82 in forum ffmpegX general discussionReplies: 5Last Post: 25th Oct 2007, 12:56
