I would like to add chapters to an AVI using virtualdubmod. this has the "import chapter" function.
I wanna know how to do that, in the sense that, IF its done with a text file, I'd like to see an example file for such a text file.
I can't find that info here, and the examples ive tried also failed. theres nothing in the help.
Background:
My DVD player also reads AVI, so I usually burn the files as files, in normal data format, not in DVD format. With the similiar named subs i can watch it just like a regular dvd. the player has a usb thing, so i usually don't even burn them. but watch them from the stick.
Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-)
Avi doesn't supports chapters.
I guess you just can use the chapters when you output as mkv using Virtualdubmod. See http://www.doom9.org/index.html?/vdubmod-procedures.htm how to use it.
But your dvd player probably doesn't supports mkv then...
So if you really want chapters you can try make a .divx using a divx authoring tool like DivX Author, DivXMediaBuilder and it might work on your dvd player if it's divx certified. -
thanks for the fast reply, i will try that. u rock!
PS and no it dont support mkv, will check on how to work the divxLooking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-)
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
Help. Avisynth Error Message "no function named limitedsharpen"
By Pitorasilo in forum Video ConversionReplies: 7Last Post: 27th Dec 2010, 06:13 -
HVX 200 P2 - Time Lapse "Recording Error" now file wont play or import!
By trevmarps in forum Capturing and VCRReplies: 1Last Post: 26th Apr 2010, 15:15 -
By trevmarps in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 25th Apr 2010, 16:08 -
Cyberlink Power Director 7 - "Create" Function Problems!
By lapetite_66 in forum Newbie / General discussionsReplies: 4Last Post: 29th Jul 2009, 20:01
