8) Hi:
Is it possible to combine 2 VIDEO_TS folders into one to burn to a DVD-R Dual layer? I know that both VIDEO_TS folders have the same file names, but has anyone ever tried this successfully?
Thanks. This looks like a great forum! My first post here..... 8)
Tony
Results 1 to 9 of 9
It is only possible to create a composite DL DVD, having common video manager (single VIDEO_TS.IFO file and common VIDEO_TS.VOB) and single folder. An easy way is using DVDRemake's 'Merge DVDs' option. It will create top menu for selection of both parts with their original menus. It is also possible there to edit navigation commands for sequential playback of titles, but this needs some experience and knowledge of DVD structure and commands.
Thanks guys. Basically, I have a 6.11G video, but is broken up into 2 discs. It is a continuous movie. So i guess using the "Remake" option is the way to go.
BTW, i'm on a mac. don't know if DVD shrink works... -
Sorry. I probably should have mentioned that to begin with
The one long video may not be a problem, since the DVD is one continuous event (a concert) that is split over 2 discs. It might actually be an improvement, rather than having to switch discs in the middle.
i'll try that software and see what happens!
thanks for the help....... -
Well in that case, it will definitely work the way you want it to, & you will still be able to skip through the chapters.The one long video may not be a problem, since the DVD is one continuous event (a concert) that is split over 2 discs. It might actually be an improvement, rather than having to switch discs in the middle.
You can do it this the last version of myDVDEdit.
Look my last tutorial which explains how add a VTS file in a DVD project.
You will have to add some commands to jump from the end of the first title to the begin of the second. As they are in different VTS files you will have to jump to a VMG Menu PGC first.
Easier than this could appear.
Jerome
VOB without audio/video_ts folders to MPEG2?
By yearofthespider2k3 in forum Newbie / General discussionsReplies: 15Last Post: 23rd Dec 2010, 13:51 -
Vob's, Avi's & Video_TS folders....
By SPORTSGUY88 in forum MacReplies: 35Last Post: 19th Jul 2009, 23:20 -
Can I combine two VIDEO_TS files?
By Levina in forum MacReplies: 14Last Post: 17th Mar 2008, 18:51 -
How do I rip DVD to VIDEO_TS/AUDIO_TS folders?
By Crimea in forum Newbie / General discussionsReplies: 6Last Post: 18th Feb 2008, 11:34 -
how do install two folders video_ts in one dvd-r
By togood in forum DVD RippingReplies: 3Last Post: 13th Dec 2007, 05:58
