Sorry I don't know which thread to put this...
Whenever I click the options to burn a mutlisession data dvd or untick the "finalize" or DAO option it still burns it as finalized. I can never get a multisession disc.
What is the problem and how can I fix it?
i used Ahead Nero Micro Lite and Ashampoo burning studio.
You cannot multisession with Dvd-rs only Dvd-rw.Dvd-rs are not rewriteable.Originally Posted by Stealth3si
Right answer, wrong reason. DVD+R supports multisession, and is also a write-once medium. The problem is that DVD-R is essentially preformatted as a single volume by design. Some drives/software will attempt multiple sessions with DVD-R, but almost no drives successfully read anything other than the first session.
That said, multiple sessions are such a compatibility headache that perhaps avoiding them altogether is best. Media is so inexpensive that cost isn't a real motivation anymore. In the most extreme case, use DVD/RW media to support multiple sessions, then burn a single-session DVD+/-R when you've filled it up. Rinse, repeat.
Yes! I totally agree. Multisession burns are very problematic. Most (but not all) standalone devices will only read the first or the last session on the disc. It's just not worth the hassle.Originally Posted by tomlee59
multi session
By didikai in forum Off topicReplies: 0Last Post: 28th May 2010, 05:44 -
used Multi-AVCHD, discs won't play in the Insignia WBRDVD player- WHY?
By Sinatrafan in forum Authoring (Blu-ray)Replies: 25Last Post: 19th Apr 2010, 08:23 -
Best "Multi session" DVD Image ??
By Anurag in forum Newbie / General discussionsReplies: 7Last Post: 13th Sep 2009, 01:22 -
FLV - Multi Joiner, Multi Splitter, Multi Advert Removal
By oz_surfer in forum Newbie / General discussionsReplies: 0Last Post: 11th May 2009, 23:16 -
Pioneer DV-400V won't read Verbatim MCC-004
By unknownsoldierX in forum DVD & Blu-ray PlayersReplies: 0Last Post: 20th Sep 2008, 15:55
