I'm pretty much done with nero, its so bloated and slow
what is a good alternative,
all i really do is burn mp3 cds/ audio cds, put video files together and make a dvd with menu.
thanks
I have imgburn,
you cant put together a dvd with menu's with it
something like dvd flick, which is actually really good except that if your title is too long on your menu, it runs off the screen!
i was hoping for one program that will do both those things, burn mp3 cds, and create dvd movies with menus, like nero is able to do,
but i can settle for seperate programs, actually im looking at dvdflick and burnaware might do the trick -
I know this is not you want to hear but really you will get the best results if you use separate software for each part of the process.
Use a dedicated video and audio encoder. Avisynth framserving to Hcenc and wavi with aften are a good combination.
Use a good dvdauthoring software like guifordvdauthor to create your dvd.
Burn the dvd files you just created with imgburn.
The above process takes some time to learn but once you do you will be very happy with the results you can get.
If you really don't want to go that route then avstodvd is considered very good for dvd creation.
Imgburn just can't be beat for burning cd's and dvd's in my opinion.Donadagohvi (Cherokee for "Until we meet again") -
There are several stripped down versions of Nero available on the Web that are not bloated. Try a search for 'Nero Lite'
You know you don't have to install everything in Nero. Since all the different apps in Nero can be installed seperately, simply install only what you want. From the info in your post above, I would install Nero Burning Rom for CD/DVD/mp3 burning and Nero Vision for making DVD's with menus. You may also have a need for Nero Recode and maybe, but not really Nero Express. Other than those, you can leave all the other stuff out.Originally Posted by m-man
Like everyone else will tell you...I would keep using ImgBurn for all DVD burning.
best alternative to nero
By marlo in forum AudioReplies: 12Last Post: 29th Aug 2010, 13:53 -
software alternative to nero to put a dvd on my HW
By marlo in forum Newbie / General discussionsReplies: 1Last Post: 19th Jun 2010, 06:36 -
Free alternative to Nero
By ddongle in forum Newbie / General discussionsReplies: 4Last Post: 23rd Dec 2009, 13:19 -
Nero messed up again, need an alternative.
By capman21 in forum ComputerReplies: 5Last Post: 12th Jul 2007, 10:19 -
ConvertXtoDVD Alternative?
By foxbox in forum Video ConversionReplies: 29Last Post: 10th Jul 2007, 17:13
