Hi,
I have been given a DVD with some footage in it which comprises of 4 .vob files on 1 DVD,
The files are named 1 to 4 on the DVD
The person who gave me the DVD has asked me to chop the first 15 seconds off the first .vob file
My questions are is this easy to do ? and how do I do it, i.e. edit the file ? and then re save ?
Thanks in advance for your answers to topic I now nothing about..![]()
Kind Regards
Piatti
Results 1 to 12 of 12
Thanks for the quick reply
The disc has 2 folders
AUDIO_TS
VIDEO_TS
The AUDIO_TS has nothing in it whist the VIDEO_TS has serveral .VOB files, 2 .IFO files and 2 .BUP files....
What are the next steps..... -
Then it's dvd-video and you can't just cut the vob as it wont work correctly after that.
You can instead use dvd shrink in the reauthoring mode to cut out the beginning but you will lose menus(if any). See http://www.dvdshrink.info/reauthor_basic.php
If you want to keep the menu I guess you can use vobblanker but it's a bit more tricky, see http://www.dvdr-digest.com/articles/article_vobblanker_page1.html -
It has'nt got any menus but the .vob files do play in order, there each in 10 min separate .vob files and play 1.vob, 2.vob, 3.vob and 4.vob
Will dvd shrink effect this ?
Kind regards
Piatti -
Wait at least a day or two before bumping your topic.
You should post a list of the files in the folder so that we know what you are dealing with here. Make sure to list the exact file names.
Did you try using DVDShrink as suggested? Do that before asking any more questions or bumping this thread again. -
I would use VOB2MPG to extract the video and audio from the VOB files into an mpg file, then edit the mpeg file with VideoRedo or Womble Mpeg Video Wizard. I would then output the results to a new mpg file (without re-encoding, of course), and author a new DVD using my favourite authoring tool.
Read my blog here.
though not freeware (but worth every penny that it is sold for) the app dvdremakepro will let you do exactly what. It opens already authored dvds with the intent to let you change or do practically whatever you like to an already authored disc. It then lets you export just the modified files to over write your originals on the hard drive. Once done it is all set to burn
this way if you need to keep the dvds full structure and everything else you can do so and not have to worry about totally re-authoring the whole entire dvd -
Originally Posted by Piatti
If you should be inclined to try Mpeg Video Wizard DVD as mentioned in guns1ingers reply, you would only need to drop the VOB files into the timeline where you could do your cuts or edits etc. Then, open the DVD maker window which will allow you to add chapter points and create menus if desired. Click export button and you have a new Video_TS folder ready for burning.
It's simple using VobBlanker (free). Open the DVD in VobBlanker. Highlight the video in the upper window so it appears in the lower window. Highlight it in the lower window and hit the 'Cells' button to the right. In the new window highlight the first cell - the one containing that first 15 seconds you'll be cutting out. Hit the Prev/Cut button and cut out what you want. 'OK' and 'Apply' your way back to the main screen, give it an 'Output Folder' and 'Process'. Here's a guide, but the procedure is so easy that you don't need it:
http://download.videohelp.com/jsoto/guides/VobBlanker/prevcut/index.php
You'll keep the menus and anything else that might be in the DVD.
Want to edit some words in a subtitle of a Vob file
By prithvi in forum SubtitleReplies: 8Last Post: 16th Feb 2011, 14:00 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 10:05 -
I want to edit one VOB file.
By happydog500 in forum Video ConversionReplies: 1Last Post: 21st Jun 2009, 20:36 -
Edit alone the vob
By gameroftheuk in forum Newbie / General discussionsReplies: 2Last Post: 7th Aug 2008, 01:23 -
EDIT! Program only converting 1st VOB file?
By chronic777 in forum DVD RippingReplies: 2Last Post: 17th Aug 2007, 04:14
