I used Sefy's guide DVDtoVCD, and it's great except for the volume on play back is really low. How to i fix this for next time and can i save what i have allready burnt to cd?
Thank you for all replys
Click on settings, then advanced in TMPG. Select audio, and normalize, and adjust the volume.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Help, the above didn't work. -
norm about 268% and it works press play to hear the changes -
where are u guys playing the VCDs in...? if u're playing in standalone DVD player...u can just use the remote and turn up the volume...if u're playing it in your comp...make sure u have a decent sound card/speakers that can amplify the sound...
Sorry, it did work when i did it properly, i've been sick with the flu, the old brain ain't working so well. Thank you all your help.
DVD audio volume too low
By efiste2 in forum AudioReplies: 4Last Post: 28th Mar 2012, 16:06 -
Low Volume on Playback
By SE14man in forum Software PlayingReplies: 6Last Post: 28th Aug 2010, 11:45 -
Low audio volume
By Daz_uk in forum Capturing and VCRReplies: 0Last Post: 29th Jan 2010, 13:34 -
Youtube: why the low volume?
By kevs in forum MacReplies: 3Last Post: 23rd Nov 2008, 06:07 -
Low volume on flv files
By drwho in forum Video ConversionReplies: 3Last Post: 22nd Jul 2007, 17:13
