For years now i've wanted to, and been pestered to do a custom build, so i'm about to bite the bullet and do just that. However i'd like to get some opinions on my proposed build, and if it is indeed good value, or i'd be better off just buying one ready made, or atleast from a place that custom builds for you. I'm looking at:
Intel Core 2 Duo E8400 Socket 775 (3.0GHz)
Asus P5KPL-AM iG31 Socket 775 onboard VGA 8 channel audio mATX
Corsair 2GB DDR2 800MHz/PC2-6400 Memory CL5 1.8V
Microsoft Windows XP Home Edition-SP3/SP2- 1 PC - OEM
Western Digital WD5000AAKS 500GB SATA II 7200RPM 16MB Cache
LG W2242S 22" TFT Monitor 1680x1050 8000:1 300cd/m2 5ms VGA
CoolerMaster Elite 330 Black Case With CM eXtreme Power 460W PSU
Sapphire HD4850 1GB GDDR3 HDMI DVI VGA PCI-E Graphics Card
For approx. £530, which is the very top of my budget. I intend to use it for video (inc Full HD)/audio/image editing mainly in the Adobe suite, playing fairly recent games, and then general day to day use. So, good deal/worth it or not?
A decent substitute for DVD Maestro
By Drakul in forum Authoring (DVD)Replies: 12Last Post: 8th Mar 2012, 22:11 -
decent vcr replacement
By yuhr in forum Newbie / General discussionsReplies: 9Last Post: 22nd Aug 2009, 13:06 -
Custom Video Converstion Help 720p to custom 720p
By powerplyer in forum Video ConversionReplies: 5Last Post: 4th Jun 2009, 15:14 -
Looking For A Decent Camcorder Under 200$
By DJboutit in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 5th May 2009, 12:13 -
A decent free DVD\CD author
By GimpGuy2000 in forum Newbie / General discussionsReplies: 17Last Post: 30th Jun 2007, 14:49
