Is there any way I could find out if I can update and to what max. for my current MB.
Windows XP Pro SP3
Pentium (R) 4 CPU 2.66GHZ
2.67GHZ 1.5GB of RAM
Mother Board
Manufacturer : Acer
Product : L4S5MG/651+
Version : Unspecified
Serial Number : Unspecified
Support MP : Yes, 1 CPU(s)
Version MPS : 1.1
Video card
Manufacturer : Nvidia Corp (Abit Computer Corp)
Model : NVIDIA GeForce2 MX/MX 400 (Microsoft Corporation)
Bus Type : AGP
Total Memory : 64 MB
Texture Memory : 185 MB
Processor : GeForce2 MX/MX 400
Converter : Integrated RAMDAC
Refresh Rate (min/max) : 56/75 Hz
I need to update to at least 128MB Minimum ram.
Thank you
John
It's a AGP (Accelerated Graphics Port) card. But I'm not sure which slot version. You can pull the card and look at this page down a ways and see a slot comparison. I'm guessing it's a 4X or 8X card, but not really sure. http://en.wikipedia.org/wiki/Accelerated_Graphics_Port
I looked at NewEgg and I saw about 22 AGP cards there, so there are plenty available. Most all will perform better than that MX400 card. Once you have determined exactly what style card you have, you should be able to find a compatible one in your area. -
It's 4x ... try stores in cabramatta / liverpool area's for best prices ... agp 8x supporting backward compatability with 4x.
Do not buy anything with "albatron" on it ... I had 2x nvidia fx5200's which didn't last the warrantee period. -
Be aware that some of the more powerful cards may overwhelm your power supply. And they will require power directly from the power supply via an adapter since your PSU is unlikely to have the right connector.
The geforce 6200 is a great card. I recently got one (256M) to replace on-board on an older PC for $25.
Thanks guys. I really value this info. I thought the MB was limited to a very week VCard. This VC is more than 5 yo. and never gave me problems, but it's no longer supported. Cnnot get updated drivers for it. The PSU is a 460W “Cooler Master Extreme Power Plus” with a 120mm cooling fan in it.
I'll start looking around. I'm not in a hurry.
Thanks and Regards
John
Upgrade video card for old Dell GX280
By neworldman in forum ComputerReplies: 1Last Post: 9th Mar 2011, 01:31 -
upgrade video card reasonable?
By gooberguy in forum ComputerReplies: 2Last Post: 23rd Apr 2009, 12:00 -
Which to Upgrade (video card/processor) to view 1080P MKV fine on AX3200?
By vmanthegreat in forum Software PlayingReplies: 21Last Post: 16th Mar 2009, 15:33 -
Upgrade video card to ATI HD4670
By hulinning in forum Media Center PC / MediaCentersReplies: 2Last Post: 9th Jan 2009, 20:55 -
Time for a Video Card Upgrade?
By dj4monie in forum Media Center PC / MediaCentersReplies: 21Last Post: 19th Dec 2007, 04:35
