Don't beat me for this question.
I cannot convert from dvd to avi with program dvd2avi version 1.76.
After I have loaded vob files with dvd2avi what is necessary to do to save as avi file?.
When I click on save avi I never get an playable avi file.
Lars
Thanks...
but could you please show me the paragraph where to find something about creating AVI files?
All I can read is how to create mpeg files.
Lars -
Well, there is no special DVD2AVI guide, because probably no one (except OGO himself) uses DVD2AVI to save an .avi. DVD2AVI is rather a frameserve tool. And you have to read several guides.
The method, that I recommend is DVD2AVI>VFAPI>VitrualDub/nundub.
1] http://www.vcdhelp.com/DVDConversionGuide/index.php?id=dvdtovcd2c.html#DVD2AVI
2} http://www.vcdhelp.com/DVDConversionGuide/index.php?id=dvdtovcd2a.html#VFAPI
3] http://www.vcdhelp.com/avi2divx.htm
http://www.doom9.org/divx4-main.htm
Maybe you want to use Avisynth filters instead of VirtualDub filters. Then frameserve with dvd2avi and Avisynth to VirtualDub/nundub.
Sure you can use DVD2AVI to convert to avi, but you can not add subs, you can not resize (use v1.82 modified by OGO instead), you can not add any filters.
If you save the avi, just select an output file name and a codec, configure the codec and that's all.
convert compressed avi files to mpeg without increase in file size?
By jasoothai in forum Authoring (VCD/SVCD)Replies: 7Last Post: 2nd Nov 2011, 06:29 -
Convert MKV to AVI/MPEG-2 High Quality file for HD author
By ronorkis in forum Video ConversionReplies: 7Last Post: 1st Nov 2010, 09:23 -
Trying to convert AVI to MPEG file smaller then 4gig
By Lisn2me in forum Newbie / General discussionsReplies: 7Last Post: 30th Dec 2009, 12:01 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36
