I used to work just fine, but now for some reason it keeps saying "video compression error. The source file is not acceptable (error code -2)" it is happening on files that it had no problem converting before.
Check the framesize of your input file or filter output if you are resizing before compression.
There's not much to do but then I can't do much anyway. -
That is almost always because you tried to compress an odd frame size like 641x480.
Make sure the frame size is an even number, IE, 640 X 480 or similar. Divisable by two or four might help if you have an odd number. If no help there, try disabling the audio and see if that works. Maybe the audio is the problem.
also happens if frame size is not compatible with profile you have chosen (e.g. HD will throw that error if you use Home Theatre profile)
try unconstrained profile to see if error goes away.
Lost ability to use Avisynth script to open .flv file with virtualdub.
By DaneClark in forum Video ConversionReplies: 4Last Post: 20th Feb 2011, 12:33 -
Need help with Virtual Dub setting
By lost123 in forum Capturing and VCRReplies: 12Last Post: 8th Jul 2010, 22:31 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 14:48 -
Suddenly can't convert VRO to DVD video
By johnsees in forum Newbie / General discussionsReplies: 1Last Post: 2nd Aug 2008, 00:30 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 16:36
