Are there any commercial software packages that allow for editing in other than 16:9 or 4:3? I have a VIO-POV helmet camera that records in a 3:2 aspect ratio (a true 720x480 with square pixels). I would like to make videos in that aspect ratio without cropping, letterboxing, or pillarboxing. I know I can use VirtualDub, but I'm looking for a program that will allow me to more conveniently add titles, transitions, etc.
Oops, meant to say 1.5:1 (or more simply 3:2) instead of 1:5 (will go and edit the original post).
I have Pinnacle Studio 12 and it seems to only let me work in 16:9 or 4:3. -
Is your ultimate goal DVD? If so, DVD only supports 4:3 and 16:9 DAR. Tell Pinnacle Studio your source is square pixel. It should then letterbox or pillarbox into a 4:3 or 16:9 DVD project. If you really want a 3:2 DAR, square pixel, 720x480 video you should be able to select a square pixel project in Pinnacle Studio.
Ultimate goal for those videos is YouTube and/or clips inserted in PowerPoint presentations.
attach a small sample of about 5mb here and i'll check vegas and pp to see if they can use your via-pov video. or a larger sample on a file sharing site would work also. if you need to cut a small sample try this tool.
makesample.zip
MPEG-1 on DVD with different aspect ratios
By DRP in forum Authoring (DVD)Replies: 8Last Post: 15th Aug 2010, 02:16 -
Aspect Ratios: 0.889 vs 0.9191
By Hass860 in forum Newbie / General discussionsReplies: 15Last Post: 13th May 2010, 03:14 -
Does lagarith support aspect ratios?
By sphinx99 in forum Video ConversionReplies: 3Last Post: 13th Mar 2010, 10:51 -
iMovie and aspect ratios
By sphinx99 in forum MacReplies: 3Last Post: 10th Mar 2010, 23:18 -
Aspect Ratios
By gayclarke in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2007, 15:13
