Hello everybody
Please Tell me steps for action
How to make Dual audio on mkv video without converting to AVI
THANKS TO ALL
Results 1 to 10 of 10
I changed the subject as tell me how doesn't say anything.
Use mkvtoolnix (mkvmerge gui) to add several audio tracks to a mkv. If you want more information you must give more information exactly what you are doing. -
Well I'm still waiting for MORE INFORMATION!
What kind of video files do you have? And give AS MUCH INFORMATION AS POSSIBLE, video and audio codec, container(avi,mkv,dvd,etc)
ANd have you even tried mkvmerge? add the video file and the then the audio and make a mkv. -
How did you get the this other audio source? Is it EXACT same length as the video? if it's from a different source you must probably manually resync it and it could be very tricky.
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
easiest way to rip dvds WITH dual audio to MKV or AVI
By angryassdrummer in forum DVD RippingReplies: 13Last Post: 19th Dec 2011, 00:40 -
converting OGM/MKV to AVI (with dual audio track)
By mwasim1 in forum Video ConversionReplies: 1Last Post: 4th Jan 2009, 22:54 -
Help! Converting mkv. to mp4 (dual audio problems)
By ir0n_ma1den in forum Video ConversionReplies: 1Last Post: 5th Jun 2008, 14:50 -
problem converting dual audio mkv
By projecttemp in forum Video ConversionReplies: 10Last Post: 18th Mar 2008, 16:53
