Hello![]()
what it s the best format for watch my bluray disk on my ps3 using ps3 (with external hard drive)and 32" tv 1080p.
I have 1080p (true hd) after ripp after use tsmuxer, and for the 32" the best is 720 p ?? (quality-size) or 1080p is best for the same size
the best
720p @ 10mps
or
1080p @ 10mps
Results 1 to 10 of 10
Why 720p if your TV is 1080p?
The TV will convert 1080i to the TV's native display format. Some HDTV sets accept 24p but not many cheap 32" will. If your set does accept 1920x1080p/24, then it will convert that to native display format.
I don't think the PS3 supports 24p. I need to check that.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Just looked, the PS3 will do 24p over HDMI, does your TV accept 24p? What is the model number?
i have ps3 60g, with hdmi cable
my tv is toshiba model ^???
edits
it s
Toshiba REGZA 32RV530U 32-Inch 1080p LCD HDTV -
OK, that Toshiba is 1080p and can accept 24p over HDMI. So why do you want 720p?Originally Posted by miss
Where did the 10Mb/s come from? Blu-Ray uses more than that even for VC-1.Recommends: Kiva.org - Loans that change lives.
because the resolution 1080p is for the very big resolution ??? (+42" ?? FOR watch the difference)
what is the difference 720p vs 1080p ?
my true hd is 13-22 go
and i want 2-3 part on my ps3 max (FAT 32 4096 MIB) -
Your TV is 1080p. You get best Blu-Ray quality feeding native 1920x1080p resolution to the TV. If you convert 1080p to 720p, the TV must convert it back to 1080p for display. You get a double conversion loss.Originally Posted by missRecommends: Kiva.org - Loans that change lives.
720p source or downsize 1080p to 720p ?
By vcddude in forum Video ConversionReplies: 4Last Post: 19th May 2011, 19:40 -
Shrinking 1080p MKV, change to 720p or keep as 1080p?
By Phat J in forum Video ConversionReplies: 5Last Post: 28th Nov 2010, 10:35 -
AutoMKV: 1080p or 720p MKV to smaller sized 720p MKV = choppy video!
By Quicky in forum Video ConversionReplies: 1Last Post: 12th Apr 2009, 20:23 -
When is 1080p too much and 720p more than enough.
By Ukrainianoiler in forum Newbie / General discussionsReplies: 21Last Post: 22nd Nov 2008, 16:38 -
1080p to 720p
By anirban in forum Video ConversionReplies: 6Last Post: 26th Apr 2008, 15:09
